93EXCivic
93EXCivic MegaDork
2/11/18 2:46 p.m.
So my car has a XM antenna on it, I want to remove it but it will leave a small hole. Is there some kind of plug I could use to fill this hole?
John Welsh
John Welsh Mod Squad
2/11/18 2:50 p.m.
Black caulk?
93EXCivic
93EXCivic MegaDork
2/11/18 2:51 p.m.
In reply to John Welsh :
Yeah I was considering that.
Knurled.
Knurled. MegaDork
2/11/18 2:52 p.m.
Black caulk may be too beaucoup.
t25torx
t25torx Dork
2/11/18 3:10 p.m.
If you can get to it from the inside, take a piece of aluminum can and JB Weld it to the back of the hole. then take some JB weld and fill the hole form above. Sand and touch up paint as necessary.
bludroptop
bludroptop UltraDork
2/11/18 3:14 p.m.
Nylon screw with a dab of caulk.   File most of the head off once tight.
2/11/18 4:14 p.m.
John Welsh said:
Black caulk?
We know Welsh loves the black caulk.
ultraclyde
ultraclyde PowerDork
2/11/18 4:20 p.m.
The heavy duty aluminum tape they sell in the HVAC dept if Lowes makes a great semi-permanent body patch for stuff like that.  Also works great as a backer to fill on top of.
Crackers
Crackers Dork
2/11/18 4:28 p.m.
+1
I've been known to do this on customer cars with coins from their ashtray.
Matthew Kennedy
Matthew Kennedy Reader
2/11/18 4:33 p.m.
In reply to Crackers :
At least three firewall holes were sealed on Wreck Racing's challenge Insight with pennies JB welded over them.
stuart in mn
stuart in mn UltimaDork
2/11/18 5:50 p.m.
If you have a decent hardware store nearby, go there and ask about rubber hole plugs - they may have something that would fit that hole.  Otherwise get online and do some searching.  I suspect you could get something from a place that sells grommets, and/or from an electronics parts house like Mouser, Digi-Key or Newark.
84FSP
84FSP SuperDork
2/11/18 8:21 p.m.
Appleseed said:
John Welsh said:
Black caulk?
Quote of the day...
84FSP
84FSP SuperDork
2/11/18 8:23 p.m.
On a serious note you could probably clean it up, dab of paint, and then a rubber insert from the auto parts store.
Crackers
Crackers Dork
2/11/18 8:34 p.m.
In reply to Matthew Kennedy :
I used the same to fix a couple holes in a friend's aluminum Jon boat.
I was relentless in asking about "my two cents".
mad_machine
mad_machine MegaDork
2/11/18 8:53 p.m.
what ever you do, refrain from using silicone. If you ever need to repaint the roof (or car) it's contamination will make it very difficult to get paint to stick there
yps1ssg3tgJ1FOLuL6fJy55QwPMOjI8UNoK0tT0lAdqXvr7wrXIw5gwboz6385Uw
