oldeskewltoy
oldeskewltoy Dork
2/12/14 6:08 p.m.
Find me 3.5" OD 19 gauge pipe... I need a 3" length
Anyone know where I could find this section of pipe??
bgkast
bgkast Dork
2/12/14 6:18 p.m.
I just looked for something similar at the Steel Yard off Columbia. They only had 4", so I made due with it. I have 3" left if you want it (I bought 6")
oldeskewltoy
oldeskewltoy Dork
2/12/14 6:20 p.m.
bgkast wrote: I just looked for something similar at the Steel Yard off Columbia. They only had 4", so I made due with it. I have 3" left if you want it (I bought 6")
Only 4" O/D?
This is to fit my flowbench, so I need 3.5" O/D .
I have 82mm (grey) and I have 84mm(red), the 19 gauge 3.5" pipe would give me 86.75mm
motomoron
motomoron SuperDork
2/12/14 6:35 p.m.
In a prior life I dealt with specifying a lot of thin-gauge steel tube parts.
The diameter spec you've given is pretty optimistic. Do you specifically need some property of 19 ga as the thickness, or are you looking for a tube that has a diameter of 86.75mm (3.415")? ID or OD?
This is what lathes are for. Start with something simple like PVC and bore the IDs you want.
Nashco
Nashco UberDork
2/12/14 6:48 p.m.
Get a piece of 3 1/2" copper "type L"...pretty damn close, you can shave a touch off the OD if necessary. 19 gage is pretty durn thin for something with such a large OD, not something I'd expect to find in a weird OD like 3.5".
Bryce
oldeskewltoy
oldeskewltoy Dork
2/12/14 6:57 p.m.
motomoron wrote: In a prior life I dealt with specifying a lot of thin-gauge steel tube parts. The diameter spec you've given is pretty optimistic. Do you specifically need some property of 19 ga as the thickness, or are you looking for a tube that has a diameter of 86.75mm (3.415")? ID or OD? This is what lathes are for. Start with something simple like PVC and bore the IDs you want.
I need 3.5" O/D so I don't have to bore a new table top... I need 86.75mm as the I/D, for that is the bore I'll be using... 86.4mm as an I/D would also be acceptable (3.5" O/D 18 gauge pipe)
tr8todd
tr8todd HalfDork
2/12/14 7:06 p.m.
3" PVC pipe should be real close. If its too small, glue a 3" PVC coupling on and turn that down. Or just use a 3" coupling or hub. Some of the toilet flanges are weird inner and outer diameters.
Streetwiseguy
Streetwiseguy UberDork
2/12/14 7:27 p.m.
Buy a chunk of 19ga sheet and a roller from harbor freight.
nDUSZSh58OQthoRAueFBISTRk9NkaFWWcateDt9FFztaqWH1fTtFzFWJzIaeHOez
