alex
alex UberDork
6/7/16 7:31 p.m.
'01 non-ABS. Am I missing something? All the lines are off, and the two nuts on either side mounting stud are both off, but that bugger ain't moving. I'm guessing corrosion has it stuck on so I'm drowning it in PB, but just thought I'd check in case there's something I've overlooked, or a trick I don't know.
AngryCorvair
AngryCorvair UltimaDork
6/7/16 10:16 p.m.
Reattach the lines and let it leak/gravity-bleed, then stomp the pedal and it will probably push the MC off the booster. I'm guessing it's stuck due to galvanic corrosion between aluminum MC and steel booster.
novaderrik
novaderrik UltimaDork
6/8/16 3:09 a.m.
Rubber mallet or deadblow hammer will knock it loose..
J0qaN6DONslhj90iU2l7Uh9gkYZLfj34bAympR8z9mevfbPNNiumTQyEpTwLeQGj
