Mr_Clutch42
Mr_Clutch42 SuperDork
4/25/18 7:52 p.m.
How about an early Boxster?
GTwannaB
GTwannaB HalfDork
4/25/18 11:35 p.m.
How about a Probe? Vote for second generation. Dirt cheap. Huge hatch for motor.
Type Q
Type Q SuperDork
4/26/18 9:01 a.m.
The answer is always Miatasmiley
java230
java230 UltraDork
4/26/18 10:52 a.m.
In reply to Type Q :
No no its not. LOL
The more I think about this the more I think a midlana style would be the best, but a rolling chassis to start with sounds much more doable and not a 4 year build.... I like the mini size/shape, but they are pretty heavy.
java230
java230 UltraDork
4/26/18 11:42 a.m.
This just popped up on the CL..... Box flares? :D
kb58
kb58 SuperDork
4/26/18 11:59 a.m.
How about a mid-mounted drivetrain in a Prius? Box flares, lowered, wide tires, just the thing to annoy shiny happy people. Only half-way kidding.
Where do you live? Reason I ask is sometimes building a car from scratch is Much easier to register than changing drivetrains in something already on the road.
java230
java230 UltraDork
4/26/18 12:20 p.m.
In reply to kb58 :
I'm in WA. No inspections, so drivetrain swap should not be an issue.....
I like the prius idea! Hmmm wonder what they weigh stripped? I doubt they handle worth a poop though.
Matthew Kennedy
Matthew Kennedy Reader
4/26/18 12:32 p.m.
In reply to java230 :
When you're doing the Wreck Racing method of vehicle modification, it doesn't matter how it handled when you started.  We set a 0.8 second margin on a 35 second autocross in a Honda Insight, because nothing about that car had anything to do with what Honda did when it was made.
java230
java230 UltraDork
4/26/18 12:35 p.m.
In reply to Matthew Kennedy :
Very true.... But If i am keeping the front end, a decent start helps!
There are no cheap Priuses (priui?) around me....
Stefan
Stefan MegaDork
4/26/18 12:41 p.m.
No no its not. LOL
Maybe pick up an old sandrail as a start?
java230
java230 UltraDork
4/26/18 12:43 p.m.
Hmmmm
Dave
Dave Reader
4/26/18 12:47 p.m.
Lotus Europa shell?
Maybe mounted in the bed of a lowered 80s Ford Ranger
java230
java230 UltraDork
4/26/18 2:37 p.m.
In reply to Dave :
Pickups are cheap....
pinchvalve
pinchvalve MegaDork
4/26/18 2:58 p.m.
Well since we didn't get this:
How about into one of these?
pinchvalve
pinchvalve MegaDork
4/26/18 2:59 p.m.
Or the back of one of these:
java230
java230 UltraDork
4/26/18 2:59 p.m.
In reply to pinchvalve :
Its a thought, but I would need CHEAP donor, and I really want RWD.
pinchvalve
pinchvalve MegaDork
4/26/18 3:00 p.m.
The older ones practically box flare themselves...
pinchvalve
pinchvalve MegaDork
4/26/18 3:02 p.m.
Keeping the Ford theme, I'd put one up front and one out back...
The0retical
The0retical UltraDork
4/26/18 3:40 p.m.
A Ranger or a Ranger Tremor would be pretty sweet. They weigh a bit less than Focus ST it appears. Make it into a  baby Lightning.
java230
java230 UltraDork
4/26/18 3:54 p.m.
In reply to The0retical :
Focus ST ~3300lbs, Id like to be ~2000-2500?  all in. Civic above should be 1500-1700 as it sits, 1990 Toyota PU's are 2700-3500 ish (im guessing 2wd short ed is ~3k?) I say Toyata just because that's what I am familiar with and would probably use. Blasphemy aside....
java230
java230 UltraDork
4/26/18 3:56 p.m.
And for a little more fun..... Its been done with a B18
The0retical
4/26/18 4:45 p.m.
Will it fit into the space an FFR 818C has available?
java230
java230 UltraDork
4/26/18 4:47 p.m.
It turns out the 1990 ish Toyota PU's in standard cab short bed are 1" shorter wheelbase than the f ST..... That would be easier than swapping it into the back if I was to leave it FWD, use the F St floor pan and hang PU stuff on it..... Its 2.5" per side skinner tho.
java230
java230 UltraDork
4/26/18 4:50 p.m.
Maybe. But thats a big jump up in $$. They say they are considering a 2.3 ecoboost option.
kb58
kb58 SuperDork
4/26/18 5:08 p.m.
"Good, good, I feel the desire growing within you."
uBtFITIbywX05FkkG1npq0R5Wj0i6SMO54nlu2rjgloWtK7WRd8r05FovBBmzGHE
