Trans_Maro
Trans_Maro UberDork
8/10/14 12:09 a.m.
How 'bout this one in the Posies Fleetliner:
stanger_missle
stanger_missle HalfDork
8/10/14 1:02 a.m.
I may or may not have been stalking CL after this thread started
The 92-96 is my favorite generation of F150. My dream unicorn would be a 92-96, single cab, flareside, 4wd, 4.9L, 5 speed truck in the deep blue color.
Like that but darker
Curmudgeon
Curmudgeon MegaDork
8/10/14 6:35 a.m.
Trans_Maro wrote: Or put a $40.00 carb kit in it and get it back on the road... Rough idle and terrible fuel economy can easily be the engine in need of a tune-up. When was your last tune up? Is your vacuum advance working? How are the plug wires? How do the plugs look? If you're getting E36 M3ty mileage, you're probably running rich. Checking plugs will tell you this. Where is your timing set? Why not do a little diagnostic work before you go spin the "wheel-o-parts" and start throwing money at it. I know the GRM collective is terrified at the thought of using a carburetor but on this extremely efficient engine design, adding EFI won't really make a huge difference for the dollars spent.
Lot of truth in this. But do keep in mind that the reason Ford went to port FI on this engine when everything else was TBI was the whole runner length thing. The parts are out there in junkyards all over the country, the know how is everywhere, it is a viable option.
I personally would avoid the whole ITB setup because that's more for RPM engines which the 300 certainly is not.
singleslammer
singleslammer SuperDork
8/10/14 9:21 a.m.
Lot of truth in this. But do keep in mind that the reason Ford went to port FI on this engine when everything else was TBI was the whole runner length thing. The parts are out there in junkyards all over the country, the know how is everywhere, it is a viable option. I personally would avoid the whole ITB setup because that's more for RPM engines which the 300 certainly is not.
The funny thing is that it can be, room what I have read. I ran across a muscle mustang or something similar article that we discussing the merits of the Ford sixes.
They were talking about a few builds that spun the 300s to 7k. With proper balancing and at least forged positions this could be done on the bottom end. The head is always the issue with these motors.
I have done some research on using LSX heads (3 heads) cut and welded together. This would likely allow for all the flow anyone could want. There is a guy who did one with 2 LS heads and epoxy. Leaks some apparently.
Curmudgeon
Curmudgeon MegaDork
8/10/14 9:28 a.m.
Oh yeah, the motor itself is tough as nails. There are some successful drag race cars using it at high RPM's. I was referring to the everyday humdrum get to work and back version.
neon4891
neon4891 UltimaDork
8/10/14 10:03 a.m.
+1 on a basic tune up, but beyond that, a factory efi conversion from a junk yard would be my pick.
I too love the engine. I want one in a bronco with an auto, too many bad memories from stop-n-go traffic with the clutch those had. Or a super cab/short bed/2wd. Or a turbo and swapped into a big 70's Lincoln coupe. Or a...
Fueled by Caffeine
Fueled by Caffeine MegaDork
8/10/14 11:20 a.m.
Junkyard FI bits + MS + turbo = http://www.ford-trucks.com/forums/250890-just-turbod-my-300-six-5.html
482 Ft-Lb's of torque
Curmudgeon
Curmudgeon MegaDork
8/10/14 12:52 p.m.
Now them's some torques!
MrChaos
MrChaos Reader
8/10/14 3:20 p.m.
disregard 300 i6.
Aquire Aussie spec Ford Barra 310T FG 4.0L I6 it makes 416hp/417lb·ft
100% factory ford engine
$2400ish before shipping in aus.
The_Jed
The_Jed UltraDork
8/10/14 4:11 p.m.
Just found an '86 Bronco with a carbed 300 six on craigslist...
vfQJe4Ee7fmEBUlrLhQvnAjUfXunaqRdPXnlNrAkV7z6fx4QfdHR0q18ZaaZJbqk
