Canute
Canute Reader
12/25/11 1:25 a.m.
Thinking about an aluminum flywheel for my 331. Any recommendations?
aussiesmg
aussiesmg SuperDork
12/25/11 7:24 a.m.
Fidenza
novaderrik
novaderrik Dork
12/25/11 9:19 a.m.
don't. unless you've got a ton of extra torque and have it geared really deep.
aussiesmg
aussiesmg SuperDork
12/25/11 9:58 a.m.
He has plenty of torque and I've run them on rotaries without issue, unless you plan to tow...
Canute
Canute Reader
12/25/11 12:46 p.m.
Nope, track car. Won't be doing any towing. The Fidanza came up on Summit. Unfortunately their cheap one, at $317, was for early engines with 164 tooth flywheels. http://www.summitracing.com/parts/FIZ-186511/
Canute
Canute Reader
12/25/11 12:52 p.m.
Any idea how much a factory 5.0 Mustang flywheel weighs? I know, "take it off and tell us" .
aussiesmg
aussiesmg SuperDork
12/25/11 1:01 p.m.
No idea of it is true but found a post claiming 16.5lbs
http://www.brothersperformance.com/p-4623-1986-95-ford-mustang-50-fidanza-aluminum-flywheel.aspx
Jegs has 13.5
http://www.jegs.com/i/Fidanza/383/186501/10002/-1?parentProductId=755918
Canute
Canute Reader
12/25/11 1:17 p.m.
Summit says 13.5 for the Fidanza 186501 too. I was wondering about the stock one. The steel ones from FMS are listed from 21-25lbs+. Nice that the 186501 can be either externally or internally balanced.
aussiesmg
aussiesmg SuperDork
12/25/11 1:21 p.m.
I have used several aluminum flywheels with the steel face, in race cars, never had a problem in any of them, the engine responds so much quicker that I have found them to be well worth the effort
daytonaer
daytonaer Reader
12/25/11 5:33 p.m.
I had a fidanza Al fw with a steel friction insert and steel starter teeth on a chebby and I was very happy with the quality and performance. Had some metal drilled from the balance pads, machine shop did not need to add any weight. I remember using locktite on the pressure plate bolts and the fw bolts differed from the iron fw bolts but fidanza included them.
Good luck!
mad_machine
mad_machine SuperDork
12/25/11 6:51 p.m.
novaderrik wrote: don't. unless you've got a ton of extra torque and have it geared really deep.
why do you need extra torque and deep gearing? I have driven a lot of cars with light flywheels.. all 4 cylinders and never had a problem
novaderrik
novaderrik Dork
12/26/11 5:07 a.m.
4 cylinder generally have deeper gears, and to me a 331 is a small engine with little torque..
i always look at things from a driver perspective, and a heavy flywheel makes the car maintain speed better on the road and accelerate smoother from stops and what not. the OP didn't say what the application was, and i just assumed "street".
aussiesmg
aussiesmg SuperDork
12/26/11 7:01 a.m.
But a 331 is a stroked 5.0 V8, should have a big fat torque curve unless you are comparing it to a 7.3 diesel, BTW who mentioned 4 cylinder?
mad_machine
12/26/11 8:14 a.m.
4 cylinder generally have deeper gears, and to me a 331 is a small engine with little torque.. i always look at things from a driver perspective, and a heavy flywheel makes the car maintain speed better on the road and accelerate smoother from stops and what not. the OP didn't say what the application was, and i just assumed "street".
I think I see what you are saying now. The "deeper" gears allow the lighter weight flywheel to spin faster, quicker.. were "taller" gears it won't see the advantage due to how much slower the engine revs up in gear.
I have only ever driven one v8 with a manual (when I was learning to drive) so I can't comment on how well a big engine responds to a light weight flywheel, but it always seemed to me that lighterweight helps everywhere, on every engine, except for smoothness and vibration
novaderrik
novaderrik Dork
12/26/11 10:26 a.m.
aussiesmg wrote: But a 331 is a stroked 5.0 V8, should have a big fat torque curve unless you are comparing it to a 7.3 diesel, BTW who mentioned 4 cylinder?
to me a 331 is a small engine, with matching smaller torque..
Canute
Canute Reader
12/26/11 3:46 p.m.
Actually, this car has an RX7 Turbo II diff - 4.30. I was thinking of seeing if I could put a 3.90 in it. When I had this engine in a Mustang I drove it with a 3.73.
Canute
Canute Reader
12/26/11 3:48 p.m.
That car weighed probably 100 pounds more than this one will and had truckloads of torque. One of my friends described it as "explosive".
Knurled
Knurled Dork
12/26/11 4:18 p.m.
novaderrik wrote: i always look at things from a driver perspective, and a heavy flywheel makes the car maintain speed better on the road and accelerate smoother from stops and what not. the OP didn't say what the application was, and i just assumed "street".
I never noticed a difference. Then again I drive rotaries, maybe V8s are different
Scratch that, I did notice one difference. A heavy (26b) flywheel makes it easier to drive a bridge port in the sub-2000rpm range because it keeps the brapbrapbrap from hammering the drivetrain so much. A light (~9.5lb + counterweight) flywheel makes it more noticeable. The heavier flywheel also allowed me to drop the idle down to ~900-1000 more easily, instead of ~1300.
That said, I'm still going to drive bridge ports on the street, and I'm still going to use an aluminum flywheel as long as I have the right counterweight. And I'm still going to upshift at around 2k-2500 on the street, 'cause that's how I roll.
All the horrible things people said would happen with an aluminum flywheel never happened. Just like all the horrible things people said about a bridge port never happened. Gotta love innernet knowledge...
Canute
Canute Reader
12/27/11 12:44 a.m.
Wow, I just took the flywheel off of my engine. It's been sitting so long I forgot what's on it. It came out to 12 pounds-ish. One more thing I don't have to buy.
Bzc44P58ITzlGf3KpofLyNn4wdis91U4LCuSswtLoendFs8ic52hP7Kd941zZiPm
