With the RX-8 engine swap still dragging along, I decided to take the Forester out for this event.
I welcome criticism, but please bear in mind that this was my third event ever. I know I should set a constant pace in the slalom instead of lift/throttle, and I kept making that mistake all day. I'm honest, though: I pretty much suck everywhere. I was 10 seconds off of the pace the experienced guys were setting. Some of that is car, but most of it is driver. I think I'm still applying rallycross inputs and getting too close to cones.
I also need more work on aiming the GoPro. I think I should put it outside the car. I still don't have a mic, but at least there is some engine noise from having the windows down.
Final (fastest) run: I lost a bit of time on the start (and everywhere else) but the clock showed I was doing better here. By this time I was a bit more confident and relaxed, too. I was still overcooking the really tight turn near the end of the course after the long sweeper. I should have slowed down more, set myself up better and maybe and gotten on the throttle earlier and while pointed in the right direction instead of letting the AWD figure it out for me.
http://youtu.be/kxoRdnifd9A
First run
Due to the course, novices needed to be "checked off" before they could drive solo. In any case, I wanted some pointers to work on for the rest of the day. I was a bit nervous and i wanted to to see how much of a Pig the Forester was going to be if it could get grip. I think it slides better than it turns.
http://www.youtube.com/watch?v=daGd2ctu2PE
Worst Run: I got checked off after the first run. no problem. This was my second run of the day. Apparently the cone I blasted in the lane change at the end caught something (probably tow hitch) on the way out and launched about 10 feet into the air on exit. The other cones were just regular knockdowns. I'm posting this to show some of the corrections I was making on the next two runs.
http://youtu.be/Ky8PNNbSPqo
Third run: There was a shifter kart in front of me and they were having a bad day out there. One of the guys wanted to ride along with me to see what the Forester was like. He's much better than I am, too, so after my awful performance in the second run, I figured it wouldn't hurt. There was a bit of a pucker moment, but rallycross experience might have saved that from getting much worse. I was guilty of trying to go a bit too fast in places here.
http://www.youtube.com/watch?v=t_4JrCXQRLM
