DeadSkunk
DeadSkunk UltraDork
5/17/16 5:00 p.m.
Could someone with an '89. or older Fox Mustang take a couple of measurements for me? I need to know the distance between the tops of the front shocks and the distance from the same points back to the firewall. I've found lots of body measurement diagrams on line ,but they don't really show those dimensions . Thanks
dropstep
dropstep Dork
5/17/16 5:13 p.m.
if no one else helps you i can measure my car, its fox platform. mustang parts fit it!
DeadSkunk
DeadSkunk UltraDork
5/17/16 6:00 p.m.
In reply to dropstep:
After seeing Fairmonts and Zephyrs with Mustang front clips I'd believe the measurements are the same.
dropstep
dropstep Dork
5/17/16 6:13 p.m.
37 3/4 center to center of the strut top bolts. exactly 12 inches from top to firewall passenger side, drivers side appears to be the same (had to move the tape out a bit to clear the wiper motor mount on d/s).
snailmont5oh
snailmont5oh Reader
5/17/16 6:25 p.m.
But, the distance between the tops of the struts varies depending on camber adjustment. On a stock car, that can be as much as 3" per side.
dropstep
dropstep Dork
5/17/16 6:41 p.m.
yeah i couldnt get an accurate measurement of the center of the strut hole by myself without using the bolts. the struts are out of my parts car but the left tower is rusty (maybe bent) and im not sure how accurate that would be.
DeadSkunk
DeadSkunk UltraDork
5/17/16 7:12 p.m.
The camber plates on my Challenge car can accommodate 34.5 - 38.5, so it looks like Fox body suspension might work. The 12" to the firewall is about 4" more than I've got so some setback is going to be needed if I go this way.
Thanks,dropstep.
rustysteel
rustysteel Reader
5/17/16 7:12 p.m.
I just measured the shock towers and distance from firewall on my '88 LX 5.0L.
I've got 37 3/4" from the centres of the the top of the struts in the engine bay. From there to the firewall is 11 1/2". Hope this helps.
DeadSkunk
DeadSkunk UltraDork
5/17/16 7:14 p.m.
In reply to rustysteel:
That shows the Zephyr and Mustang are pretty close then. Thank you,too.
rustysteel
rustysteel Reader
5/17/16 7:16 p.m.
In reply to DeadSkunk:
No problemo.
dr4XpJy3lpuBVbGpq8psOQGBtdrGhRZXLmsIX3lNKJY4FQau7CZerf0u31DPMNGN
