petegossett
petegossett SuperDork
11/15/10 10:46 a.m.
I figured the drive would be easy enough, either flip the R/P in the front rear axle(boy that sounds weird saying it....), or just flip the whole axle over, and connect them both with some type of sprocket/pulley/gear going to jackshaft to the engines.
I'd be more worried about trying to get the steering aligned. If you wanted to keep the geometry correct, you'd need more Ackerman on the front front axle, than the back front axle.
Ugh. Makes my head asplode....
Spinout007
Spinout007 Dork
11/15/10 12:19 p.m.
He's "selling it for.a friend who passed away" and knows nothing about How they were mated.
Matt B
Matt B HalfDork
11/15/10 12:33 p.m.
I wonder if that friend died of autoerotic asphyxiation in a southeast asian hotel room?
Too soon?
Rufledt
Rufledt Reader
11/15/10 12:50 p.m.
I second the 'I dare someone to $2011 it' comment. The autox would be a bit tricky, but it would make for a good youtube video!
ansonivan
ansonivan HalfDork
11/15/10 12:56 p.m.
Answer to all driveline questions?
Infinite Improbability Drive.
Either that or strategic use of a wormhole through which the drive shaft might pass on it's way to the rear differentials.
mad_machine
mad_machine SuperDork
11/15/10 1:14 p.m.
it the forward rear diff looks like it has two flanges.. one for the input and one for an output the second diff.
I cannot imagine the drivetrain losses on this car
bravenrace
bravenrace Dork
11/15/10 1:48 p.m.
I don't think any jag rearends had two flanges.
mad_machine
11/15/10 2:06 p.m.
you and I know that.. but look closely at the "forward" rear diff.. it is definatly very long and seems to be symertical front to back.I wonder if he found a way to bolt the nosecond from one onto the back of another
maddabe
maddabe New Reader
11/15/10 2:08 p.m.
"Rack-en pinion steering" That about sums it up.
What was that Tyrell? P34 I believe.
maddabe
maddabe New Reader
11/15/10 2:13 p.m.
Just read the ad again. "the detentions are 204in long 81in wide and 40in tall" This guy's mom drank WAY too much while pregnant. Detentions! Too berkeleying funny.
Spinout007
Spinout007 Dork
11/15/10 2:36 p.m.
Yeah I got a laugh outta that one too.
petegossett
11/16/10 5:07 p.m.
It ended just short of $4500. Seems pretty high for that atrocity/monstrosity.
Rufledt
Rufledt Reader
11/16/10 6:25 p.m.
I wonder, if you were nerdy enough and had a LOT of time, would it be possible to make that thing 8 wheel steer?
Jensenman
Jensenman SuperDork
11/16/10 8:22 p.m.
I though I had a fevered imagination.
Looking at that front diff, I think what he did was: make a custom center section to hold the carrier bearings then 'flipped' another housing to point a second pinion gear backwards and high up (two pinion gears running on the same ring gear) then turned the second diff over in the carrier to put that pinion in line with the front one. But two 12A's to move all that? Um, I'm not seeing it. I say 12A's because as near as I can tell from the pics, the bottom intake halves are RB pieces. The 13B carb conversions used the stock bottom half and a RB upper section.
gigolojoe
gigolojoe New Reader
11/16/10 11:40 p.m.
my girlfriend likes it....
i guess the upside is i can't do much worse on my own cars
bravenrace
bravenrace Dork
11/17/10 6:03 a.m.
What that car needs are two LS1's, or maybe an Allison airfcraft engine. I think it's cool, in a Batmobile sort of way.
2JFxUv7fMNCTDRJ6hPSj3NBgoNvHAroZ9t59bzmVXikyebsgNMjOFMsYMJhgrnBl
