Gearheadotaku
Gearheadotaku PowerDork
12/23/16 9:25 p.m.
When I turned off the headlights on my car last night, I was greeted by the lovely sounds of grinding gears from the headlamp motor.
Berkley.
Time for a GRM fix. Its too cold and expensive to buy and install new parts.
This doesn't work on all models, but it fixed my 2000 Firebird. Works on Fieros too IIRC.
Raise headlamp manually
Remove actuator arm from shaft
manually spin motor untill shaft turns 180 degrees
put arm back on
manually turn motor untill lamp is down
cycle lamps to ensure proper operation.
There are 2 gears inside, 1 large plastic gear that the actuator arm hooks to, and a small worm gear on the motor. Over time the plastic gear wears out, but only on one side. It only moves 180 degrees to open/close the lights. This process spins the gear around and now you are using the unworn side!
C4 Corvettes and 3rd gen Firebirds require removing and taking the motors apart. They don't tend to wear out gears, but there are little plastic 'pucks' inside that degrade and crumble. They can be replaced with nylon rod for pennies and put back together.
Always allow pop-ups!
06HHR
06HHR HalfDork
12/23/16 10:15 p.m.
There was a guy down in Tampa who used to sell replacement gears machined out of brass. $75 for the pair but they would likely wear down the worm gear they meshed with. Sold the 97 Formula I had with those gears in the motors. I really miss that car
novaderrik
novaderrik UltimaDork
12/24/16 2:35 a.m.
the easiest and best solution is to not get a car that goes into "fugly mode" when you turn the headlights on..
Trackmouse
Trackmouse Dork
12/24/16 11:07 a.m.
In reply to novaderrik:
Hey now! Every car I've ever owned has been in fugly mode!
You could do like the jdm "bros" and disconnect the wiring to the motors, manually raise the lights only "halfway" up, and look like a gangsta from circa 2003 with your mad tyte jeans hipster firebird.
Brian
Brian MegaDork
12/24/16 9:50 p.m.
Brilliant! And I love pop ups. Coolest part about my '88 Accord.
Donebrokeit
Donebrokeit Dork
12/24/16 11:50 p.m.
I love pop up lights
So do other people.
cT4vIoojAZS6J6TqHhmmbPqKCyKfHaryLKc2LsfkjECQqPPd1RnZV4nIB9WGiWmK
