2.0dohc
2.0dohc Reader
6/16/21 5:42 p.m.
So my daily driver is in need of some new suspension. '15 FRS
Other than full rear end/diff mount, tranny mount and steering rack bushings it's all stock.
I was looking at the Meister ZetaCRD, TEIN Flex A or the CSG Spec version if I end up going with coilovers.
My goal is to end up with something that is a bit stiffer and a little lower than stock.  The roads in southern Arizona can be rough and I find myself on dirt roads so I don't want something too low or stiff.
Suggestions?
OldGray320i
OldGray320i Dork
6/16/21 6:30 p.m.
A bit stiffer and a little lower than stock I'd recommend the favorite lowering spring and B6s or Konis, I think a better value than coilovers.
I run coilovers on the Miata, the budget Goodwin Feals, love them, but after running a street oriented set up with konis on the E36, it's a little better daily set up.   I also did just springs and shocks on the e30 when I had that, and it daily'd great for six years between the girl and me.
SoAZ roads are sometimes less than stellar,  I know.   I will drive more distance for smoother in nearly all cases.
goingnowherefast
goingnowherefast Reader
6/17/21 9:11 a.m.
For daily driving I'd highly recommend the classic tried and true Sachs Performance Package dampers + RCE Yellows combo that is so popular in the GT86 world.
You can get the package with nearly new dampers for ~$850
Example: https://www.ebay.com/itm/324561379445?hash=item4b915da075:g:lAcAAOSwL0ZgbwRg
RCE Yellows: https://www.racecompengineering.com/collections/2013-brz-fr-s-86/products/racecomp-engineering-yellow-springs-2013-brz
z31maniac
z31maniac MegaDork
6/17/21 9:22 a.m.
Came here to recommend RCE Yellows as well, but I'd go a step further and add new dampers while you have it apart.
https://www.racecompengineering.com/collections/2013-brz-fr-s-86/products/racecomp-engineering-bilstein-shock-combo-package-brz-fr-s-86
qDURvYtw7QyqbJAaurzhlR2lmRZPq1K1prSeUYLgQRWMOwyLpnFU9fq5DJAtWJRx
