44Dwarf
44Dwarf SuperDork
7/24/12 9:48 a.m.
Anyone know of a web site with Fuel filter data like pressure ratings, end fittings sizes, overall dimensions, micro size, etc?
With the injectors out to get cleaned on the race car I'm going to look in to better filtration and swap out my steel braided rubber lines with PTFE steel braided line. I had a 40 micron filter in the system and less then 24 inches of flexible line all the rest was / is steel hard line. Dummy me had the filter back after the flex line coming out of the cell but it should have been right before the injector rail. Live and learn.... Anyway trying to find off the shelf 43psi injection filter that i can put some AN adapter fittings in.
Thanks for the help 44
Ranger50
Ranger50 SuperDork
7/24/12 10:22 a.m.
In my expericnce, you should have two filters, one 10 micron and one 50 or 100 micron. Put the large filter before the pump and the smaller one after.
As much as I hate them, UPR Products probably has the cheapest filter out there, as they are blantant copies of others. Or can you live with 60 psi from the Vette regulator/filter?
44Dwarf
44Dwarf SuperDork
7/24/12 11:31 a.m.
yes have sock filter in cell no problem thier. Russell now make a nice push on adapter that uses threaded end cap so no plastic squeeze tabs. So looking for cheap but low micron filter for right before the rail for max protection.
4g63t
4g63t HalfDork
7/24/12 11:40 a.m.
Mitsubishi Eclipse GSX?
44Dwarf
44Dwarf SuperDork
7/24/12 2:05 p.m.
Realy like some sort of catalog that show data on the OEM filters out there.
What years mitsu?
Dr. Hess
Dr. Hess UltimaDork
7/24/12 3:29 p.m.
Check out the WIX filter site, www.wixfilters.com . They have all the specs on there. Fram may have the specs too, which you can then cross over to a WIX.
4g63t
4g63t HalfDork
7/24/12 5:16 p.m.
90-94 91-92 GALANT vr4 too
44Dwarf
44Dwarf SuperDork
8/14/12 6:12 p.m.
UPDATE: I bought a "kit" from Speedway $34. Came with a cheap filter not the nice unit shown in the add! But did come with nice russel fittings to go from the 3/8 line with the smooshed lump type fitting to -6AN males. http://www.speedwaymotors.com/Hi-Pressure-EFI-Fuel-Filter,46386.html
uses wix part 33190
Birthdays
pcYYgeKhhaTbiQ06GwOe8pO5yuqWoSe9AZuJVdn9eQT9vErXHUx68XKdMRJunfvq
