L5wolvesf
L5wolvesf Dork
9/16/23 8:09 p.m.
I need to replace some of the bolts in my gear puller set. In helping my neighbor get a brake drum off a couple of the ungraded bolts stripped. If figure replacing the bolts will be easy but also wondered if I should upgrade to graded hardware.
I am happy with the set overall and have used it a number of times. So no need to replace the whole set just several bolts. I do not use a puller on a daily, weekly or monthly basis. Just as needed.
As I see it here are the pros / cons:
Pros of upgraded bolts – they will be stronger and last longer.
Potential cons of upgraded bolts – the stronger bolts could strip the threads of whatever part I may be pulling.
Patrick
Patrick MegaDork
9/16/23 9:54 p.m.
Part of me wants the bolts to be the fusible link, the other part of me has never damaged a part I was pulling with grade 8 bolts that I have been using on my balancer and steering wheel pullers since the ones that came with them stripped or bent
L5wolvesf
L5wolvesf Dork
9/16/23 10:15 p.m.
You read my mind. Don't tell anyone about the other stuff you saw there.
Qw4M51mMJBHhij6ZvyLAXEdTIxxi1NgTybZfDsZHXV7piGMdzWPAqAd9c7eVca8c
