I don't even have my Saab C900 on the road yet and already my brain is filled with rallyx fever dreams, so naturally it's time to talk about skidplates. In keeping with the Challenge-compliant budget, cheap is good and cheaper is better. I want a plate that is 12x48" - that should cover the vital bits. I know I'm unlikely to need such a thing for rallyx, but if I'm building something that bears a passing resemblance to the decrepit shell of something that might once have looked vaguely like a rally car, it's going to have skidplate, dammit.
I understand that ideally I'd use something like 1/4" aluminum, but that's probably going to be expensive and difficult to shape. So to questions:
- Solid plate vs. a grate of bar stock welded to 2 or 3 crossbars. The latter is probably easier to fabricate, but will it protect effectively? How wide is too wide for the gaps? For plate, what's the minimum thickness needed to be effective (remember, rallyx, not stage rally)? How about vertical bracing or other strengthening? Any other brilliant ideas for how to set this up?
- Attachment points. How many do I need? The factory plate, which covers the front from the valance to the crossmember, mounts with five bolts, though I'm not sure what sort of loads this plate is intended to absorb. If I extend back to cover the remainder of the transmission, will another two bolts at the rear be sufficient? Regardless, I'll probably have to weld in an additional piece of square tubing to attach the rear of the plate.
- Speaking of the factory plate, would it be madness to just weld some additional metal to it to extend coverage back to the firewall? It seems reasonably strong, probably enough for rallyx.
- Any suggestions for cheap materials that might work here? I scoured the metal pile on the last town dump day, but I couldn't find any sheet metal that was more than appliance outer shell thick. I did grab some 3ft sections of roughly 1" square steel tubing , but I don't think that's ideal, as it would be hard to bend and reduce ground clearance.
