Would an LS power steering pump work with a Miata steering rack, or would it mess up the feel? It would be easier to keep the GM pump on the LS engine in my Challenge car, rather than fab a bracket and use a Miata one. I'm ASSuming the GM pump puts out a higher flow, but I know nothing about power steering systems.
stan_d
SuperDork
8/3/19 12:19 p.m.
Did the car the engine came from have a rack or box ? From what I have learned the box uses a higher pressure than the rack. I think it should be fine. My chevy LT1 pump powered my 240sx rack just fine.
Ransom
PowerDork
8/3/19 12:57 p.m.
If needed, could you use one of the power steering adjust valves? Hrm, was it Tilton? Heidt's!
https://www.heidts.com/part/adjustable-power-steering-valve-ps-101/
In reply to stan_d :
The engine is out of a 2003 Chevy Trailblazer EXT , so it was attached to a rack.
In reply to Ransom :
That's kinda neat, but not budget worthy for a Challenge car. Maybe usable post Challenge if I autocross the car.
FM uses a resistor in their PS setup and it felt great. https://www.flyinmiata.com/cts-v-adaptor-restrictor.html
The only other option is either an overboosted rack or loop the line for the challenge and forget PS.
Maybe I'll see what it takes to fit a Miata pump. That will involve a new bracket, pulley and possibly rerouting the accessory belt. The Challenge is aptly named.
