triumph5
triumph5 Dork
12/14/10 6:21 p.m.
Moss motors sells a plug in 12v electric blanket she can sit on, wrap around her legs, huddle under.... Bun only, try cabellas
triumph5
triumph5 Dork
12/14/10 6:40 p.m.
It's designed for one's lap/legs. Look it up at Mossmotors.com
Try a camping/RV store, they might have something that can be retrofitted into the seat...might be a bit hard to find, though. You sort of need a 12volt heating pad you can put atop the foam padding in a seat, but under the fabric, that will hold up year round.
SO, how about finding a seat already with a heater in it at a junk yard, test it before buying, and then put it in the seat as you reupholster it between now and X-mass morning!
Junkyard_Dog
Junkyard_Dog Dork
12/14/10 6:52 p.m.
If you want to go the DIY route most 90s seat heater elements can be removed once the seat skin is off. I used Range Rover pads for my Miata. Add switches and you're done.
If you want a kit I'd go with whatever Moss sells.
Ian F
Ian F Dork
12/14/10 6:58 p.m.
Victoria British sells add-on kits.
http://www.victoriabritish.com/icatalog/sg/full.aspx?Page=36
I installed a similar kit in our Spitfire with marginal results... basically: they don't work despite everything testing out fine. Not sure why.
wlkelley3
wlkelley3 Dork
12/14/10 7:03 p.m.
I got SWMBO seat heaters last Xmas.....installed in a 2010 Hyundai Sonata. 2-temp heaters. When we looked at new cars, a few of the dealers said they could and would install bun-warmers in a car w/cloth seats if we wanted, as long as we pay for it. So I know they are out there but don't know of a specific brand. Sorry.
internetautomart
internetautomart SuperDork
12/14/10 7:10 p.m.
don't know about how good they are, but my local guy sells these: http://www.amdistributors.com/CATALOGS/mobile/1qzCHECK_001.pdf
jrw1621
jrw1621 SuperDork
12/14/10 8:02 p.m.
Ian F wrote: Victoria British sells add-on kits. http://www.victoriabritish.com/icatalog/sg/full.aspx?Page=36 I installed a similar kit in our Spitfire with marginal results... basically: they don't work despite everything testing out fine. Not sure why.
The must have been Lucas reproduction items to have so perfectly replicated the effectiveness of the british electronics
mrhappy
mrhappy Reader
12/14/10 8:25 p.m.
Should work on a seat as well. diy here
belteshazzar
belteshazzar SuperDork
12/15/10 6:04 a.m.
NAPA sells them. I bought a kit for my wife's car. I'll let you know how it goes. Retails for around $100 per seat, ymmv.
Giant Purple Snorklewacker
12/15/10 6:41 a.m.
These used to be under $15 - they are light as a feather, waterproof and awesome for sitting on a rock wall in the woods on a 12F day (assuming the rest of you isn't naked, that is).
The same company makes whole "seat" ones that extend up your back that would be perfect for a car seat.
Ian F
Ian F Dork
12/15/10 8:05 a.m.
No kidding... and the annoying part is the car has an aftermarket wiring harness, so power supply is not an issue.
Ian F
Ian F Dork
12/15/10 8:29 p.m.
Yeah... if they're going into a car that could have had them, I'd try the OE-retrofit route.
DrBoost
DrBoost SuperDork
12/15/10 8:39 p.m.
I've got a set, they are Seat Comfort Systems. Hi and low settings. PM me if you are interested.
Z6KWyvHpYqJX2O9vpNzeeJiYXz1apwoZalXGAxojEtr5EgDJ0zOjyzhYXTiXRYLP
