NOHOME SuperDork
12/3/14 11:14 a.m.
Project uses Ford 8.8 center section and at this point original Miata rar hubs.
I can get axles from either Boss Frog or the Axle Shop for $1000. Fair enough.
But then I see where the FF guys are selling a similar axle for like $350 or so.
Is there a less expensive path for the Miata rear axles that I should be aware of before I pull the trigger? Is there a DIY option that might apply where I make my own bits? Never done CV work to date.
bgkast
bgkast SuperDork
12/3/14 11:53 a.m.
Also interested. I will shortly be in a similar situation needing axles that fit Miata on the outer ends and Chrysler on the inner ends.
JohnyHachi6
JohnyHachi6 Dork
12/3/14 12:11 p.m.
Check out the FF forums. We bought 3 axle shafts there from guys who got the IRS kit and ended up not using it. Picked up all three for around $100 or so.
If you run the FF axles, you will still need to figure out the wheel hub side. You can have the miata hubs re-broached to fit the cobra axle cup splines, have the shafts re-splined to fit in miata outboard CV cups, buy a hub made to fit both the cobra axle and the miata upright, or get some t-bird/cougar/MkVIII hubs and have them turned down to fit the miata bearings. We did the last option at Wreck Racing with out V8 miata. If you do that, you'll have a 5x4.5" bolt pattern on the back of the car and won't be able to run miata rotors without a little more machine work to either the hubs or the miata rotors.
DaveEstey
DaveEstey PowerDork
12/3/14 12:23 p.m.
With RX7 conversions we use Ford exploder inner CV, custom length shaft splined on the other end for RX7 outer CV.
NOHOME SuperDork
12/3/14 8:47 p.m.
This seems like both a logical path and a better price.
http://monstermiata.webs.com/differentials.htm $650 for the axles and the broaching. Still need to deal with two way shipping and the PITA to do so, so its not going to be a huge savings.
dBbASpYpNdw8xS2HXJM7gzDH5gz5CWuAp1XZOwCz0mpRD8sjHS9DrQ2jmXxesHiT
