10/24/22 5:18 p.m.
Not sure if this is a great idea or not.
06HHR (Forum Supporter)
06HHR (Forum Supporter) Dork
10/24/22 5:26 p.m.
That looks like an Eaton M62?  After googling some pictures, maybe a version of an M90..
earlybroncoguy1
earlybroncoguy1 Reader
10/24/22 5:44 p.m.
You'd have to spin that pretty fast to make any meaningful boost on an LS at high rpm.
Possible? Yes.
Efficient? No.
Nockenwelle
Nockenwelle New Reader
10/24/22 6:12 p.m.
Especially with the already-slipping single 6-rib belt leaving 1/4 of the pulley hanging in the breeze.
Blowers are cool, always will be. Cooler if you can rock one on a budget. But I smell some serious mismatch here.
Dude (Dudette?) has enough fab chops to weld that all together and collected enough aluminum scraps/pieces to do so, but spray-bombed what I presume is a 5.3 straight from Joe Dirt's Silverado. He then used what looks like a 5/16 rubber fuel line to single-feed the carb. I'll take stabbing by screwdriver before committing that sort of fuel delivery/fire hazard blasphemy.
He knows to use a good belt, but not the right belt.
The throttle setup is straight death-trap, single return spring included. Carb does not display indications of sharp tuning.
Headers look like expensive ones. Header wrap is smart and well-done, but kills headers.
Temp sender has thread sealer on it. No.
It appears more total time/effort was expended here that just picking up the right blower to make real power...
I'd love to instigate an acceleration contest with this one.
Kreb (Forum Supporter)
10/24/22 6:45 p.m.
ASSuming that's a M90, I don't know if it's going to do any more than preheat the air. Shame, because the workmanship looks pretty good. Different story if that's a Whipple, but that looks too small.
kb58
kb58 UltraDork
10/24/22 9:11 p.m.
I've seen such situations before, where someone has awesome fabrication skills, but poor design/engineering skills, and sometimes mistakes one for both.
GTwannaB
GTwannaB Dork
10/24/22 9:18 p.m.
Is this was at the challenge he would be lauded with kudos and wreaths.
kb58
kb58 UltraDork
10/24/22 9:47 p.m.
It's forum mob mentality. If the builder comes on here and explains, suddenly we'll be understanding and supportive...
earlybroncoguy1
10/25/22 10:01 a.m.
In reply to kb58 :
Just because you can, doesn't mean you should.
Captdownshift (Forum Supporter)
Captdownshift (Forum Supporter) MegaDork
10/25/22 10:08 a.m.
If it was an m112 and they were running a massive pulley, it could work. I consider that it's a project that's merely in proof of concept stage as M62s and M90s are much easier to find than m112s.
hiMRehr15UM8iGaXYqTD6gNnhFeeopgvEUjb1zHerQ8BgF3bcJGw9tUulePbrr5q
