z31maniac
z31maniac SuperDork
4/4/11 7:35 p.m.
So I aquired another little E30 project.
paint isn't as nice as it looks, needs hood/trunk/rear bumper minimum repaint and the rest needs a cut cut/polish
I picked it up on the cheap because it needs a headgasket/cracked head, still runs and drives, but a bit of milk in the oil.
The interior is near mint, only 91k miles so I assume the rest of the drivetrain is as good as it feels (though it is an autotragic, that will be remedied shortly).
However, all day I've been thinking, "If I have to replace the headgasket anyway, shouldn't I replace it with an MLS and ARP studs..............just in case?"
What say ye?
AngryCorvair
AngryCorvair SuperDork
4/4/11 7:54 p.m.
nice find. i heart red/black E30 ragtops with plastic bumpers.
Giant Purple Snorklewacker
4/4/11 8:03 p.m.
z31maniac wrote: However, all day I've been thinking, "If I have to replace the headgasket anyway, shouldn't I replace it with an MLS and ARP studs..............just in case?" What say ye?
Skip straight to an S52.
amg_rx7
amg_rx7 HalfDork
4/4/11 8:05 p.m.
Was thinking the same thing...
"if I have to replace the headgasket anyway, why not just drop in a later motor with more powa..."
z31maniac
z31maniac SuperDork
4/4/11 8:06 p.m.
^I did that in my bronze car, not going down that road again. I was just thinking about throwing on a cheap turbo set-up until the real engine goes in ~12-18 months down the line.
5.3L
simplecat
simplecat New Reader
4/5/11 2:48 a.m.
to be honest, a 'cheap turbo setup' with the associated stuff is going to cost more than a 5.3/t5 swap.
mtn
mtn SuperDork
4/5/11 3:35 a.m.
Mikey likes it!
318 or 325?
92CelicaHalfTrac
92CelicaHalfTrac SuperDork
4/5/11 6:23 a.m.
simplecat wrote: to be honest, a 'cheap turbo setup' with the associated stuff is going to cost more than a 5.3/t5 swap.
Meh. A true junkyard warrior could turbo that thing for well under a grand.
z31maniac
z31maniac SuperDork
4/5/11 6:59 a.m.
^Precisely. Although if I get feeling frisky, I'm sure even just the fresh headgasket and headbolts would be good for 9-10psi.
It would also be fun to see how long the automatic lasts with some extra power.
simplecat
4/5/11 7:11 a.m.
That's true, but that same junkyard warrior should be able to do the 5.3 swap for under a grand too. It sounds like the OP is comfortable with turbos, so maybe that's the best direction for him to take it. personally I try to move toward the goal then away from it. Meh. A true junkyard warrior could turbo that thing for well under a grand.
z31maniac
z31maniac SuperDork
4/5/11 8:54 a.m.
No, the 5.3 swap requires either a remote booster, slotted firewall or conversion to a dual master, booster less brake setup.
Custom engine/trans mounts have to be fabricated, etc.
I probably won't do the turbo thing, it just keeps running through my mind.
L8wa994h7yNIcEl1rNaVITVtQMiAGqgIRyzb5uIwljBoYm0GGcVOYXPVks0Qq1BE
