zordak
zordak Reader
7/2/22 11:49 a.m.
O.K. I have an 06 Eclipse with the V6. I died on the road yesterday. I got it home and started looking at it this morning. Hooked up my scan tool (which I have used on this vehicle before) it says it cannot communicate with the vehicle. I pulled a coil(coil on plug) hooked up my spark checker and did not see a spark when cranking the engine. I suspect a bad ecu. I cannot find any information on further checks to confirm a bad ecu. Also it sounds like a factory type scan tools is required to replace one. Any advise or information would be helpful TIA.
Tom Suddard
7/2/22 11:53 a.m.
I'd start with the basics, here's one of our how-tos:
https://grassrootsmotorsports.com/articles/troubleshooting-101-basic-steps-when-your-car-wont/
I'd suggest checking for spark by spraying some carb cleaner in. From there, you can move on to diagnose fuel or timing.
Javelin
Javelin MegaDork
7/2/22 11:57 a.m.
Battery voltage and amperage? Also check your battery cables and where they go to. I've had similar issues with a corroded ground.
zordak
zordak Reader
7/2/22 12:23 p.m.
The car cranks easily I suspect plenty of battery voltage and good grounds. As stated above using a home made spark checker and there is no spark.
EvanB
EvanB MegaDork
7/2/22 12:32 p.m.
I helped with an Evo X that had similar symptoms but wouldn't crank. No ecu communication and the fan was running with key on. Ecu was fried and had to go to the dealer to get a new one flashed.
Dusterbd13-michael
Dusterbd13-michael MegaDork
7/2/22 12:32 p.m.
Sounds like either a bad ECU, or wiring issue. Have you checked fuses?
zordak
zordak Reader
7/2/22 12:45 p.m.
not yet. there is power to the data connector.
Mndsm
Mndsm MegaDork
7/2/22 1:04 p.m.
I would guess bad ecu if the code reader failed to connect, or something bad in the harness along the way. You have critters?
zordak
zordak Reader
7/2/22 1:40 p.m.
No critters no sign of defective wiring.
Slippery
Slippery PowerDork
7/2/22 1:57 p.m.
Does that car use a crank position sensor?
Streetwiseguy
Streetwiseguy MegaDork
7/2/22 2:27 p.m.
Ecu is about the 63rd thing that makes a car not run...
buzzboy
buzzboy SuperDork
7/2/22 3:28 p.m.
Crank Position Sensor would be my first guess.
06HHR (Forum Supporter)
06HHR (Forum Supporter) Dork
7/2/22 4:03 p.m.
Unfortunately the way to check for a bad ECU is generally to swap in a known good one. Check fuses, fusible links and grounds. I think the tipoff is that your scan tool won't connect, but id exhaust the obvious before getting a replacement.
7/2/22 9:32 p.m.
Computer not getting power will cause no communication, too.
zordak
zordak Reader
7/4/22 4:12 p.m.
O.K. to close this out, I started with checking fuses. Found the #9 fuse under the hood to be bad. replaced fuse and it blew on trying to restart. A google search brought up that the O2 sensors are on that fuse. I disconnected the sensors (all 4) and replaced the fuse again and it started right up. I am in the process of replacing all 4 sensors as this thing has over 200,000 mi I figured it would be best. Side note the crank and cam position sensors are also on this fuse.
WonkoTheSane
WonkoTheSane UltraDork
7/4/22 5:05 p.m.
Glad you figured it out, and really glad it wasn't the ECU itself!  Thanks for updating the thread for those of us following along at home.
24cZ5CybpEwDYNxmnk3UfXo5eqsiJkdnnCrEyqB2VekBvsrZRBcRw0GsGJWgIWi9
