BrokenYugo
BrokenYugo UltimaDork
8/23/16 5:25 p.m.
In reply to stan:
I could be wrong, but I don't think there is really a whole lot to making a stick axle handle, like you said, it's just that nobody bothers aside from dirt track stuff. Mount it with a well designed 4 link (most probably aren't and bind) you could use a split wishbone on an I beam axle but you'll have to live with however much roll resistance is built in (the axle is forced to twist when the suspension articulates). You bend the axle (or pie cut and weld if it's a tube) to get however much static camber you're willing to put with, and then all of your tuning is in caster, toe, springs, shocks, and sway bars.
jmc14
jmc14 Reader
8/23/16 5:54 p.m.
stan wrote: Following with great interest. I've been looking at doing this for two years. Gathered catalogues, took pictures and looked for inspiration at the hot rod cars shows I've been attending (Good Guys, etc). Not a lot of cars with turning in mind it seems. My buddy who's very into cars -mainly hot rods- said "I don't care about turning" after I told him I'd like a hot rod that can turn (i.e. run autocross too How low is your '27 jmc14? Is it hard to drive on the street?
The frame height is 4.5 inches. I haven't finished the car. So, I haven't driven it yet. But, I built a Cobra replica and several other similar cars with 4.5 inch clearance. I drove those cars a lot and never had a problem. This car, with out front or rear overhangs, shouldn't be a problem.
stan
stan UltraDork
8/24/16 8:19 a.m.
My GT6 had 5" of clearance, so I can relate to most clearance issues. I was mainly wondering about just seeing around in traffic. I remember the first time I drove my 914 and was shocked at how little I could see all of a sudden. This car looks to be even shorter.
unevolved
unevolved SuperDork
8/24/16 1:23 p.m.
stan wrote: Just saw this: https://indianapolis.craigslist.org/cto/5703091489.html Shoot, what do we change to make this click-able now??
Link
Easiest way to do it is an href tag. Not sure why the forum doesn't do it automatically anymore.
href instructions
stan
stan UltraDork
8/25/16 8:22 a.m.
Link Easiest way to do it is an href tag. Not sure why the forum doesn't do it automatically anymore. href instructions
Great.
Thanks!
iYfhTBoQGEXgPghPMhigtfDkp8FVcRQcB24PZSNlb7FgQACvzHTFoMLWUlNWlxko
