Matt B
Matt B SuperDork
1/13/15 12:38 p.m.
mr2peak wrote: 6UL's look awesome. 15x8 for the square setup, they fit perfectly. Don't have a pic of them on my Mk1 unfortunately :(
Really? What offset and tire size? Were you running stock spring perches? I thought some people had to do some massaging to run 15x7.5. My 16x7 with 205/45/16 barely clear my stock perches up front.
bmw88rider
bmw88rider HalfDork
1/13/15 3:30 p.m.
I fail at Wheel ID :) Good thing is you can still get the Enkei 92's new.
Jerry
Jerry SuperDork
2/1/15 2:35 p.m.
Taxes filed. Time to revisit these suggestions!
Feedyurhed
Feedyurhed SuperDork
2/1/15 4:39 p.m.
chili_head wrote:
Wally wrote:
BBS RS Goodness. I want a set for the MINI
That is flat out gorgeousity!!
Jerry
Jerry SuperDork
2/2/15 6:16 a.m.
I saw these at Tire Rack. Decent price, I like the color combination:
TireRack
$120 for 15x6.5
carbon
carbon Dork
2/2/15 8:14 p.m.
Jerry
Jerry SuperDork
3/16/15 1:05 p.m.
Finally made up my mind. Drag DR-27 silver machined lip. Couldn't resist the exposed allen bolts... $100 each at Discount Tires locally. Now to decide on tires. (They have Kumho Ecsta AST for $69 and BF Goodrich g-force Sport Comp-2 for $88 in size 195/50-15)
JohnRW1621
JohnRW1621 UltimaDork
3/16/15 1:32 p.m.
My MR2 did not like tires that had a v-tread so if either of those do, I would choose ones that do not.
My MR2 would shimmy badly on v-treads. Research pointed toward bad bushings in the steering rack.
Ran perfectly smooth with non v-treads.
Jerry
Jerry SuperDork
3/16/15 2:11 p.m.
In reply to JohnRW1621:
Kumho Ecsta AST:
92dxman
92dxman Dork
3/16/15 2:19 p.m.
I'd go with the BFG's.
JohnRW1621
3/16/15 2:58 p.m.
BFG looks better, but, are there other choices?
Jerry
Jerry SuperDork
3/16/15 4:09 p.m.
Those are the two choices at the place I'm buying the wheels, in the size I want. Or at least had on the other MR2 when I bought it so I know they work... 195/50-15
JohnRW1621
3/17/15 5:39 a.m.
No guarantee you will have the problem I had but if you do, the answer is not tie rods but rather bushings inside the actual steering rack.
I personally bought two different tires for the front end as my solution.
CAT3JnPi11kw8Q173K1WZMqAHFlZ2dPz4qa7ealU5cjSY3d1P6jzoQkPIKxncVrd
