bgkast (Forum Supporter)
bgkast (Forum Supporter) PowerDork
4/30/20 11:36 a.m.
I picked up a cheap Chinese universal wiring harness for the Midlana project at a swap meet. Why spend 200 to 300 bucks, when I can spend 50 I thought... well I think I figured out what that extra money gets you... complete instructions in English.
The quality of the harness seems fine, the issue is that the diagram on the single page of instructions doesn't match the actual unit. The table in the directions also doesn't match the unit or the diagram right above it. I colorized diagram to match the harness, it was impossible to follow as received and didn't totally match the diagram.
The basic layout is easy enough to understand, there are 4 bussed groups of fuses. The relay controls the horn.  Even if the labels don't match the diagram the circuits can power whatever I want if I change the sticker on the cover of the box.
What I can't figure out is the turn signal flasher. It is a 2 terminal style flasher. In every other wiring diagram I have seen the flasher is in series with the positive wire to the signals. On this thing one side is connected to the a fuse on the "always hot" bus, the other side is connected to a fuse on the "hot when ignition is on" bus. Both of these will be at +12V when the ignition is on. How is that supposed to work? The input and output wires shown at the flasher don't exist, only the two black wires that run to the fuses.
It seems to me that one side of the flasher should be disconnected and run to the turn signal switch, but I've been staring at it so long my brain may not be working fully. Am I missing something?
4/30/20 6:23 p.m.
Looks like I'm not the only one perplexed.laugh
DirtyBird222
DirtyBird222 UberDork
4/30/20 6:39 p.m.
One reason why I avoid Chinese products at all cost. Good luck figuring this one out.
Patrick (Forum Supporter)
4/30/20 8:25 p.m.
Just ordered the same one on ebay, i'll tell you in a couple weeks.
alfadriver (Forum Supporter)
alfadriver (Forum Supporter) MegaDork
4/30/20 8:43 p.m.
There's another relay for the flashers.  One specific for that- so that output is probably the power to the flasher relay.  Which has 2 other inputs- one for right, one for left. The emergency flasher turns on both.
Since you are doing your own car, are you planning on LED lights?  Or regular incandesant?  If you get LED's, you need a specific digital flasher realy- as the incandecent relay actually uses the resistance of the light bulb to time how often it flashes (which is why it flashes faster when one bulb is out).
dculberson (Forum Supporter)
dculberson (Forum Supporter) MegaDork
4/30/20 8:43 p.m.
It's not the output it's the outpet. It's where you hook the cat up that yowls every time the flasher relay fires.
5/1/20 12:07 a.m.
In reply to alfadriver (Forum Supporter) :
I believe the single flasher relay provided on the box can be used for both turn signal and emergency flashing. Even using two I can't see how the one provided would be able to function with the same voltage on each pin.
I'm going to use LEDs. This flasher relay claims to work with LEDs but I'm dubious.
5/1/20 6:10 a.m.
Not sure about that wiring diagram either- not an electrical person- I'm not specifically familiar with the normal grounding path to make turn signals work.  But having all of it fed by one 12V power signal would be correct.  Normally, all injectors run from a common, single, 12V power supply- lights are a piece of cake, especially turn signal lights.
Curtis73 (Forum Supporter)
5/1/20 10:45 a.m.
I'm not sure how it works when you have the same flasher for emergency (4-ways) and turn signals, but I do know that bgkast's diagram fits what seems correct.... except one thing.  The 12v power going to the flasher would need to somehow be split into hot and switched so the 4-ways work all the time and the turn signals only work with ignition power.
I would think a relay (rigged to come on only with ignition power) in line between the turn signal switch and the flasher would do just fine, but I'm not sure how that would work in your fuse box with both pins getting power with ignition.
Jeepdriver73
Jeepdriver73 New Reader
8/12/24 5:47 a.m.
In reply to bgkast (Forum Supporter) :
Well I'm new on this forum ,so hello from Holland!
The main reason i registered on this forum is because when looking for info for figuring out this Chinese wiring harness i stumbled on this thread.
Bought it two years ago to use in my 73' j4000 truck.
I'm interested to hear if one of you have found a solution for the blinkers to get working!?
I'm not a electrician or expert , but taking my time with this kind of job has been given the best end results in the past.
My idea after trying out and using a test light was to cut or disconnect one side of the wires at the flasher (so you split up the two fuses and wires and make two separate lines and can add a extra flasher for hazard lights.
If I'm correct then it's possible to split this fuse box into four sections!? (Red wire ,red with white stripe wire , brown wire and black with yellow stripe wire)
I'm going to use this on a mechanical diesel engine , so not much electric needed except lights ,starter and alternator with GM column switch.
I hope that digging up a old thread isn't a problem!?
Thanks for having me on this forum!
Cheers
Mees
rustomatic
rustomatic HalfDork
8/12/24 6:59 p.m.
I just put pretty much the same harness on my Willys.  Everything is working, except for the flashers; short of this, it's the nicest wiring I've ever had in a hotrod.  Did you even need turn signals in 1956?
Reviving a dead thread is the magic of the internet at work.
californiamilleghia
californiamilleghia UberDork
8/12/24 7:10 p.m.
can you use 2 flashers boxes , one for left and one for right  side ?
then when you need 4 way flashers use  another switch that goes to both flashers.
Jeepdriver73
8/13/24 5:47 p.m.
In reply to rustomatic :
So what did you use for the flasher instead on your Willys?
My jeep has a steering column with the GM style wiring for turn signal etc.
So I'm going to disconnect the two fuse sections that includes the flasher and adding a second flasher relay for the hazard lights.
Everything else is almost sorted and labelled.
rustomatic
rustomatic HalfDork
8/15/24 8:42 a.m.
In reply to Jeepdriver73 :
I haven't addressed the lack of turn signals yet.  My Willys came with no wiring at all, so I was pretty stoked to get basic lights and switches from this basic-ass harness.  Eventually, I will delve into this . . .
Jeepdriver73
8/19/24 2:28 p.m.
This is how I did it.
Disconnected one of the black wires from one side of the flasher (unclipped the metal tap from the plastic connector)
Added another longer wire into the connector and got the flasher working when connecting it with the purple wire in the steering column.(GM)
Added another flasher for the hazard lights on the other short black wire (fused on the other bank of the fusebox) and connected that onto the brown wire on the steering column with a longer wire.
So got my wiring almost sorted and going to put it into the truck the coming weekend!
Got a bunch of other new wires in house for getting to the rear lights.
For the front i got a pre-made wiring harness with a couple relays for getting the main load from the light switch.
Let's see what's next on the list.
Thanks people for all your input!
Cheers
TCPOAcEmanmR5mrN97tKYc33geBgk95G0LysakX6J5RdyYunsMBwoPgGswCA9Dzd
