On the fender well of an '86 Caddy, it's got two tubing fittings that are not connected; also nearby is a corked off Schraeder Valve connected to 1/8" plastic tubing (may not be involved).
I assume it's part of the silly 80s emission system but could be cruise control. I have a Haynes' on order.
![](https://i.imgur.com/nwJUS0c.jpg)
![](https://i.imgur.com/bmmFv2R.jpg)
It looks aftermarket thanks to the wiring and zip tie, but it is an 80s GM so who knows.
The schrader valve fitting looks like air shock stuff to me. Maybe to pump up load handling shocks or add pressure to front shocks? Maybe the aftermarket dealie was an air pump for the air shocks??
Woody
MegaDork
1/2/20 3:04 p.m.
That's the seventh Fetzer valve.
Looking at '86 Cadillac engine compartments I don't see it. Could be aftermarket.
Naturally as soon as I post this I found one. Seems it's factory. Tracking it down.
Looks like an auto level system.
Or at least was.
I found this:
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/01/02/1577999124_2020_01_02_21_05_171_mmthumb.png)
which shows a similar pump underhood with a nylon line going to it similar to yours. So maybe it is factory. I also found this:
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/01/02/1577999187_2020_01_02_21_06_252_mmthumb.png)
which says it's a compressor for a 1986 Cadillac with air ride. I'm guessing what you've got is a dryer (the plastic cylinder on the right) and a pump (on the left) and someone's put in standard shocks so the air ride has been disabled. Or, it's still got air shocks but they're leaking and so disabled and giving the poor thing the ride of a boat on stormy seas.
In reply to dculberson :
The thing on the right has a hard plastic line going down and back between the block and master cylinder. Heading towards?
Found pic.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/01/02/1577999667_used-1986-cadillac-deville-forsale-8031-17959073-74-1024_mmthumb.jpg)
Update:
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/01/02/1577999908_untitled-1_mmthumb.jpg)
Ahh, it was an option. A pair of air shocks. The word "electronic" is fairly terrifying given it's 1986.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/01/02/1578000310_untitled-1_mmthumb.jpg)
Makes sense as it carried coffins. Ever pallbear one?
One day I'm gonna open one of these threads and nobody is going to know what it is. I've been here for years, and it hasn't happened ever. But it will. I believe it.
In reply to lnlogauge :
It has. Once. With some form of tools....
GM used a similar, but likely less reliable compressor on Escalades and such with air shocks well into this century.
T.J.
MegaDork
1/2/20 4:20 p.m.
In reply to Woody :
It's all ball bearings nowadays.
Yup... airbag pump.
I think the schrader valve is aftermarket which was a common thing... when the pump died, people bypassed it and put a cheap tire valve on it to fill it themselves.
I have an airbag pump from a 96 Caprice wagon which is very similar to that one.
MegaDork
1/2/20 4:41 p.m.
I recall posting that. Wish I could find the thread cause to this day I still think about it on occasion.
Pete
Curtis73 said:
Yup... airbag pump.
I don't think that's how airbags work. Pumping them up from a schreader valve manually in the event of an impact would be too slow. I think they use an explosive charge to deploy rapidly.
![](https://i.gifer.com/61ln.gif)
pinchvalve said:
Curtis73 said:
Yup... airbag pump.
Well, you have to have a trained squirrel under the hood to flip a switch in the event of an impact.
Suspension airbags, ya kooky fool.
You had to bring those up, didn't you?
In reply to Brett_Murphy :
Yup!!!
I will totally take that action
