cfvwtuner
cfvwtuner Reader
10/12/22 9:03 a.m.
As it's been a good 15 years since I've been motorsporting, I keep thinking more and more about jumping back in.
I currently have this 2013 Jetta with the 2.5, 145K on the clock.  I'm on the fence about buying something cheap just to thrash or to run this car.  I would plan on running 16's with 225/50 200 TW tires.
The issue I've had since I got the car is the brakes arent great.  I have bled them once already.  In a panic stop situation the pedal is kinda soft and the car feels like it wants to pull, but generally stays straight.  Also, at a stop on flat ground, I can slowly push the pedal to the floor.   If the hill holder thing is active the pedal is hard as a rock and wont go to the floor.   Pumping the brakes on a flat doesnt seem to make any difference. would this lead straight to the master?  Is the fact that that the car has a vacuum pump just making the pedal way over boosted? It's a fairly common mod to remove them with this engine, although mostly due to oil leaks.  Or is the master just bad?  Could it be a old or sticky caliper?
I've heard braded lines over the stock rubber will help pedal feel a bit and plan on installing those if I can figure out the main issue.
Mr_Asa
Mr_Asa UltimaDork
10/12/22 9:17 a.m.
Are you losing any fluid?  The fact that you can eventually push the pedal to the floor is concerning.
How long does this take? Length of a red-light, maybe less? What happens after that? Does the car eventually start to creep forward/can you overcome the brakes by giving it gas (if its an auto)?
Brotus7
Brotus7 Dork
10/12/22 9:56 a.m.
For what it's worth, I'm having the same exact issue in my wife's 09 Sportwagen.  Brakes were fine, then I replaced all the calipers, pads, rotos, flex hoses, parking brake cables. I suspect the master cyl went dry at some point during the job and air got into the abs system, but I'm having a hell of a time bleeding it out.  I've tried using the vagcom to activate the ABS pump, but still haven't gotten a good pedal.
The pedal is firm with the car is off, but the bite is really low when it's running - and creeps down but doesn't hit the floor.  Car still stops fine, but it isn't confidence inspiring vs my GTI that has a higher, firmer pedal.
To be absolutely sure, I'm replacing the master at the end of this week (bench bleeding it first...), then rinse-repeat the bleed process.
I'd start with bleeding the brakes with you activate the ABS pump.
KPVGB4QjYDU6wnwm4djdttksr029xH1iFaWHOLr6qMGz5FQFJ6Io4fqP1gosQPAk
