HiTempguy wrote:
curtis73 wrote:
but the proper tow vehicle for a 9k billboard is a 3/4 ton.
No, the proper tow vehicle is whatever a manufacturer recommends.
I must preface this by saying that I respect your opinion and your knowledge, but you just lost a lot of credibility right here. The manufacturer ratings are bean-counters' way of covering corporate butt and marketing. Period.
Example: 96 Caprice with the tow package. Rated to tow 4800 lbs. The tow package got you an oil cooler and 2.73 gears instead of 2.43. 96 Impala SS came standard with higher rate springs, stiffer valved shocks, a bigger oil cooler, two transmission coolers, and 3.08 gears. It was rated for 3000 lbs. ![](/media/img/icons/smilies/googly-18.png)
Another example: the last couple years of GMT400 3/4 ton trucks. Most were rated in the 9000-10,000 lb towing range. After a few years, customer feedback about ride harshness led GM to spec D-range tires instead of E, but the tow rating stayed the same.
A third example: My friend's 01 Land Rover Disco. It is rated for 6800 lbs towing with a wet noodle air suspension, short wheelbase, and inadequate brakes. What did he do? Went and bought an ultralight 6900-gvw travel trailer that was 31' long and took it into the rockies for a vacation.
The manufacturer also can't compensate for driver experience and ability, whether they live in the mountains of WV or the 70-mph winds of the flat Nevada desert where its legal to tow doubles. They can't know if you're towing a 5er, a flatbed, a gooseneck, or a travel trailer. They can't anticipate the distance from the tongue to the axles. They can't anticipate if you will replace tires with the right size and load rating or if you buy $200 Michelins or $100 generics. They can't anticipate that you'll replace shocks with $29 econo-bounce brand or Bilstein. Will the customer buy $30 Dura-squeal brake pads, or good ones?
Manufacturer tow ratings have NOTHING to do with how much they can safely tow. They have to do with how much money they will have to shell out in warranty repairs and lawsuits. Manufacturers put a weight number on it. If you think that any trailer under that weight is safe, you are grossly mistaken.
But, like I said, I mean no offense. I just couldn't possibly disagree more with your statement.
