toddgreene
toddgreene New Reader
9/19/09 8:07 a.m.
A freind asked me about the HIGH Oil pressure his vehicle was experiencing... Now I'm curious...
My first thoughts were that he had a bad gauge or sending unit.
How can oil pressure be high? Other than maybe a parasitic loss of power, is there any harm to having high oil pressure?
Thanks,
Todd
Xceler8x
Xceler8x Dork
9/19/09 8:20 a.m.
With too high oil pressure you could end up the same as if you dropped off Paris Hilton in Antarctica - Blown seals.
High oil pressure could cause some gaskets to leak that are already weak.
It could be caused by a clogged filter or a stuck closed oil relief valve on the pump.
emodspitfire
emodspitfire New Reader
9/19/09 10:09 a.m.
It can cause excessive wear/strain on the oil pump drive.
iceracer
iceracer HalfDork
9/19/09 10:38 a.m.
Most likely the pressure control valve is stuck. Worse scenario, blown oil filter. Had that happen on a friends Ford.
wbjones
wbjones Reader
9/19/09 8:19 p.m.
Xceler8x wrote: With too high oil pressure you could end up the same as if you dropped off Paris Hilton in Antarctica - Blown seals.
curtis73
curtis73 HalfDork
9/20/09 2:44 a.m.
Accidentally used oil that was too thick?
ncjay
ncjay Reader
9/20/09 7:52 a.m.
Exactly what does he think is high oil pressure? A sudden increase would worry me if the guage is working properly. My engines normally see 70 to 80 psi cold which is not a problem. The weak spot (hopefully) is the oil filter. A cheap one will blow out. In my experience, if there is a sudden increase in oil pressure, it usually means something in the engine has moved or broken.
O2GQ3WlbrxPX3ZPCw9fpgZJiPdybzsG1Ks3yVp8j4J0Xyob95f1XxO6deo8GXgaY
