SyntheticBlinkerFluid
12/11/14 8:19 a.m.
Bangshift just posted this up. This is kind of cool. A fuel mat that sits in the bottom of your gas tank instead of a normal pickup.
http://bangshift.com/general-news/must-see-holley-just-changed-fuel-system-game-big-way/
12/11/14 8:26 a.m.
How long does it last and how much does it cost? If it's 10 years and 2 digits, I'll literally take 2.
fasted58
fasted58 PowerDork
12/11/14 8:33 a.m.
How berkeleying cool!
First thought was... see if NASCAR will allow it, that'd be a game changer right there.
Gearheadotaku
Gearheadotaku PowerDork
12/11/14 8:48 a.m.
My Firebird needs one RIGHT NOW! That thing will fuel starve at a 1/3 tank in a corner.
DaveEstey
DaveEstey PowerDork
12/11/14 8:53 a.m.
Wow, think of the weird fuel cells you could design thanks to this.
12/11/14 9:06 a.m.
Gearheadotaku wrote: My Firebird needs one RIGHT NOW! That thing will fuel starve at a 1/3 tank in a corner.
I've been advised to keep my Corolla at 1/2 tank or more now to prevent fuel starvation. It left the factory like this.
Fueled by Caffeine
Fueled by Caffeine MegaDork
12/11/14 9:15 a.m.
Years ago, I had a recruiter call me looking for someone with labview experience and a racing background to work in bowling green KY on carb test items. I didn't have enough labview experience to make it happen, I had some.... Ohhh what could have been.
mndsm
mndsm MegaDork
12/11/14 11:33 a.m.
In reply to GameboyRMH:
That didn't change I'm subsequent generations. I've got a 101 and a 103 that have wandering gas gauges. Toyota designed horrible fuel pickups.
bgkast
bgkast UltraDork
12/11/14 12:52 p.m.
I'll take one for the elise tank I'm using in my Midlana. Wide, narrow tank with the pick up on one end is a recipe for starvation.
Sonic
Sonic SuperDork
12/11/14 1:09 p.m.
Yup, I could use some for the lemons cars.
Dusterbd13
Dusterbd13 SuperDork
12/11/14 2:27 p.m.
Take my money!
novaderrik
novaderrik PowerDork
12/12/14 5:05 a.m.
Looks like a bigger version of those goofy pickups that have been out for a couple of years now that won't suck air as long as it's damp..
bmw88rider
bmw88rider HalfDork
12/12/14 7:47 a.m.
I like it. If the cost is reasonable, I could see a lot more EFI conversions out there. That is the one thing that has prevented me from going EFI on my classic is the cost to get an effective fuel pickup. This totally solves that problem.
Jarod
Jarod Reader
12/12/14 7:50 a.m.
Are they going to make similar for oil pick ups? Or is there a reason that would not work?
Ranger50
Ranger50 PowerDork
12/12/14 7:54 a.m.
In reply to Jarod:
I would imagine a viscosity issue of gas vs oil.
I like it as you could position the mat to where you need it for fuel pickup.
Dusterbd13
12/12/14 9:03 a.m.
Fuel pickup is the reason why the multiport conversion on thw duster stalled. 600 for an in tank pump? Hell no!
Knurled
Knurled PowerDork
12/12/14 12:44 p.m.
GameboyRMH wrote: How long does it last and how much does it cost? If it's 10 years and 2 digits, I'll literally take 2.
I'll take three, and my place of work may order a gross.
Ranger50
Ranger50 PowerDork
12/13/14 10:39 a.m.
http://instagram.com/p/wjbsHXtWOu/
WilberM3
WilberM3 Dork
12/13/14 11:27 a.m.
very interesting indeed! the XJ-R needs about 12 gallons of fuel, or roughly 60% full to avoid fuel starvation...
CGLockRacer
CGLockRacer Dork
12/13/14 11:41 a.m.
Im going to go see if they can work in a saddle tank for my RX-8. It fuel starves below 1/3 tank on track.
novaderrik
12/13/14 8:19 p.m.
Dusterbd13 wrote: Fuel pickup is the reason why the multiport conversion on thw duster stalled. 600 for an in tank pump? Hell no!
now you'll be able to spend $300 for just the pickup and still have to buy the pump..
that's progress..
Knurled
Knurled PowerDork
12/13/14 9:40 p.m.
now you'll be able to spend $300 for just the pickup and still have to buy the pump.. that's progress..
Sucking an air bubble at 22psi boost can cost a lot more than $300.
I have a surge tank setup rigged on my car, which works but can still get vapor lock problems as I've discovered. Meanwhile, stage rally rules dictate that vehicles may only have one fuel tank, and a surge tank counts as a fuel tank, so there are a lot of people who would be extremely interested in this.
Plus I've heard of more than one instance where a DNF occurred because gravel sawed through the fuel filler tube, and then the tank got a bunch of crud in it, which got into the pump. I assume that the same hydrophilic/aerophobic properties (if those are the correct terms) also make them really badass fuel inlet filters too.
WonkoTheSane
WonkoTheSane Reader
12/14/14 7:55 a.m.
I was playing with this yesterday.. It blew my mind how effective it really was. This is one of those technologies that is indistinguishable from magic..
dean1484
dean1484 UltimaDork
12/14/14 9:39 a.m.
Good and bad for NASCAR. There will be little or no warning when you are getting low on fuel.
wbjones
wbjones UltimaDork
12/14/14 12:18 p.m.
CGLockRacer wrote: Im going to go see if they can work in a saddle tank for my RX-8. It fuel starves below 1/3 tank on track.
same for my CRX
FTqPb8J40N5k4MY8matx25lbB7iCYLSojpgksvtrpo92T04FZ5SBLRluV9r00NbK
