1 2 3 4 5
Trans_Maro
Trans_Maro Dork
2/13/11 12:38 a.m.
Ignorant wrote: Ohh no.. What if they go Drive by wire? Think of the safety concerns...
Maybe that's how they will get rid of Toyota.
The cars will be cheating before they hit the track.
pres589
pres589 HalfDork
2/13/11 3:46 a.m.
Get up get get get down, NASCAR "technology" is a joke in your town.
AquaHusky
AquaHusky Reader
2/13/11 9:18 a.m.
pres589 wrote: Get up get get get down, NASCAR "technology" is a joke in your town.
Now that song will be stuck in my head today.
oldeskewltoy
oldeskewltoy Reader
2/13/11 10:25 a.m.
so many stupid response....
Some of why they are running faster now..... They are running alcohol/gas mixture now, and they have changed their aero again.
triumph5
triumph5 Dork
2/13/11 1:21 p.m.
Maybe that's how they will get rid of Toyota. The cars will be cheating before they hit the track.
Can't wait until KIA formally introduces their car; you'll be apoplectic
Xceler8x
Xceler8x SuperDork
2/14/11 9:27 a.m.
Pardon my ignorance here...
How does the Aussie Saloon series handle this type of thing? Is the Aussie series a "run what cha brung" kind of thing or do they regulate the cars as closely as NASCAR?
triumph5
triumph5 Dork
2/14/11 10:04 a.m.
This came up in a prior thread, and according to the poster, who said he was an official, it's tightly regulated. However, it still makes for enjoyable viewing! Talk about hungry, aggressive drivers on very interesting tracks and street circuits!
4cylndrfury
4cylndrfury SuperDork
2/14/11 10:06 a.m.
aussiesmg wrote: Yawn, call me when they turn right
srsly
iceracer
iceracer Dork
2/14/11 10:10 a.m.
The latest thing. NASCAR doesn't like the two car draft that occurred Sat. nite. Too fast, so they want to tweak the cars cooling sytems so that the pushing car overheats.
One thing that does amaze me is the engines. How they can run a two valve, single cam, pushrod engine to such high rpm. 8600 in qualifying and there were reports of well over 9K on Sat.
spitfirebill
spitfirebill Dork
2/14/11 10:30 a.m.
While they are at it, go to 4.6 liter SOHC engines.
triumph5
triumph5 Dork
2/14/11 10:38 a.m.
iceracer wrote: The latest thing. NASCAR doesn't like the two car draft that occurred Sat. nite. Too fast, so they want to tweak the cars cooling sytems so that the pushing car overheats. One thing that does amaze me is the engines. How they can run a two valve, single cam, pushrod engine to such high rpm. 8600 in qualifying and there were reports of well over 9K on Sat.
They did the tweaking to the oil and water cooling systems BEFORE Sat night's race. I'm sure there'll be more "tweaking".
Yes, the engines ARE interesting; most of the teams have had valvetrain dynos so at least that part of the engine wouldn't fly apart. Actually, CarCraft mag did a build up of a Ford 289, IIRC, that had a 9600rpm redline, and that was back in the early 90s.
One thing I've never seen, which I'd like to, is the valve actuator on 18k rpm F1 engine. As well as the area around the wrist pin.
Ranger50
Ranger50 HalfDork
2/14/11 10:46 a.m.
The biggest thing they do is run a 1/2"-9/16" diameter pushrod with a hair diameter oiling hole through it. Then they spring it with the longest and strongest spring with cooling jets aimed at the springs. The resistance to bending far outweighs the weight, which is about ziltch in the overall scope of things.
Javelin
Javelin SuperDork
2/14/11 11:57 a.m.
Watch NHRA Pro Stock. 10,000 RPM.
Slyp_Dawg
Slyp_Dawg Reader
2/14/11 6:17 p.m.
I remember watching the telemetry from a Cup car a while ago, and I believe it was phoenix? the revs got up to 10,000
anyway, tweaking the cooling system so that the following car overheats, that just seems a bit shady to me. "because you are doing so well, we are going to compromise the cooling on your car and risk the destruction of your finely tuned race engine". well done Nascar, well done
triumph5 wrote: One thing I've never seen, which I'd like to, is the valve actuator on 18k rpm F1 engine. As well as the area around the wrist pin.
I believe the most recent issue of F1 Racing has a link to an article outlining one of the most recent Toyota F1 engines, I do believe the engine they looked at was the last year of the 3.0L V10 rather than one of the newer 2.4L V8s. it's a pay-to-see, but if you're the engineering type or want to try your hand at designing engine parts, it might be worth it just to skim off a thin layer of awesome for your own designs (as long as they were one-off, otherwise Toyota might be a bit mad...)
93EXCivic
93EXCivic SuperDork
2/14/11 6:21 p.m.
Xceler8x wrote: Pardon my ignorance here... How does the Aussie Saloon series handle this type of thing? Is the Aussie series a "run what cha brung" kind of thing or do they regulate the cars as closely as NASCAR?
The Aussie series uses more or less spec cars. It is pretty much NASCAR down under except on road coarses.
triumph5
triumph5 Dork
2/14/11 6:23 p.m.
Pro Stock, Funny car, and Top Fuel are all rev limited to 10k.
9/16ths to 1/2" pushrods boggle the mind. And those strong vlalve springs, what do the cam lobes look like after a race? OTOH, what metal is the cam made of?
I'll have to check out the current issue of F1 magazine.
wbjones
wbjones Dork
2/14/11 7:36 p.m.
novaderrik wrote: NA|SCAR and Goodyear have also been talking about going to a bigger wheel diameter- 17" instead of the current 15". they said it was to allow bigger brakes packages and to better reflect what the car makers are selling- when was the last time you saw a brand new full size sedan with 15" wheels on it?. they did some testing last summer, but i don't know what will come from that.
F1 still runs 13's ..... though I hear there is talk of change....
wbjones
wbjones Dork
2/14/11 7:43 p.m.
so what ...??? it'll still be another spec series.. (with the grill covered up (qualifing) and no headlight decals no one can tell one car from another)
even more so with the control NASCAR will exert over the ECU controlling the FI...
Xceler8x
Xceler8x SuperDork
2/14/11 8:47 p.m.
Thanks for answering my question guys. Just curious...
z31maniac
z31maniac SuperDork
2/14/11 10:05 p.m.
Slyp_Dawg wrote: I remember watching the telemetry from a Cup car a while ago, and I believe it was phoenix? the revs got up to 10,000 anyway, tweaking the cooling system so that the following car overheats, that just seems a bit shady to me. "because you are doing so well, we are going to compromise the cooling on your car and risk the destruction of your finely tuned race engine". well done Nascar, well done <
Seems no more gimmicky than a button that adds 80 hp or a wing that lays down to add 20kph on the top end.
I love F1, but I don't understand the desire to destroy the skill/improve the "show," for the less-than-casual fans.
F1 is already the most watched event in the world.
I can't until Ecclestone is no longer in charge.
oldsaw
oldsaw SuperDork
2/15/11 1:41 a.m.
z31maniac wrote: Seems no more gimmicky than a button that adds 80 hp or a wing that lays down to add 20kph on the top end. I love F1, but I don't understand the desire to destroy the skill/improve the "show," for the less-than-casual fans. F1 is already the most watched event in the world. I can't until Ecclestone is no longer in charge.
I wish things would change when the little troll finally feeds the moss under a bridge somewhere.
But, like Nascar, F1 has prioritized tv ratings over sporting pretensions.
Slyp_Dawg
Slyp_Dawg Reader
2/15/11 8:10 a.m.
true, it does seem like a gimick, but there's a difference between a gimick that improves performance and a gimick that intentionally risks damaging/destroying what very well may be THE most advanced/finely tuned example of a pushrod V8 just to "even out" the field. it would make much more sense to hand out individual handicaps based on finishing position, aka in the 1st race, everyone starts their car out as-is, and based on who wins, in the 2nd race weekend, certain handicaps are handed out (a restrictor plate that is slightly smaller than an unrestricted FI carb, or a restrictor plate slightly smaller than everyone else, or even a set of smaller venturis if they go to a IRTB-style EFI, or just throw weight at the car like the BTCC does). that should work better and make more sense than screwing everybody over equally, which is probably why they won't do it
mndsm
mndsm SuperDork
2/15/11 8:14 a.m.
Sealed spec series. Get a bunch of Tauruses and Impalas and Camrys and whatever else from Hertz or Avis, and put the keys in a bowl, and let em go for it. I'd probably buy a ticket to that mess.
Trans_Maro
Trans_Maro Dork
2/15/11 9:26 a.m.
triumph5 wrote:
Trans_Maro wrote: Maybe that's how they will get rid of Toyota. The cars will be cheating before they hit the track.
I drive a Toyota daily, I love my car.
I don't watch Nascar, it's bloody boring and I have all my teeth.
I do like a good laugh though.
iceracer
iceracer Dork
2/15/11 9:49 a.m.
One more thing, Comparing drag racing engines to NASCAR engines is like comparing potatoes to oranges. One has to last 5 seconds, while the other has to last 4 hours. Personally, I find F1 races boring.
1 2 3 4 5
pvSFtGdY8lEyxCSQIBOpmNt3CWLPFDf0CsXXU0HRmUVlCoH7xd7e0wk4MR03ZgtX
