calteg
calteg SuperDork
9/15/22 10:38 a.m.
Got a line on a cheap 2010 CTS wagon. I remember hearing rumors that the earlier generations of that motor had timing chain issues, does the GRM hivemind have any direct experience?
9/15/22 1:13 p.m.
They are fine, make sure it has enough of the right oil in it and change it on a regular basis.
If it is AWD, do not pass Go, go directly to removing the transfer case and apply a lot of moly grease to the input splines.   You know the OMG ANGLE GEAR issue with Volvos?  CTS4s have the same problem for the same reason but a lot more expensive to fix.
calteg
calteg SuperDork
9/15/22 1:44 p.m.
It's RWD, so no issue there
NickD MegaDork
9/15/22 1:49 p.m.
Like Pete said, check the oil and change it regularly. And if it does need them, those can be done in-car fairly easily. No need to drop the engine like some of the transverse applications
chandler
chandler UltimaDork
9/15/22 2:14 p.m.
Is this info the same for an xt6? Think that's what my wife is wanting.
iansane
iansane Dork
9/15/22 3:30 p.m.
Add two turbos and it's certainly fun.
NickD MegaDork
9/15/22 3:55 p.m.
An XT6 is a completely different platform with a transverse engine, and the new 3.6L is a much more complex beast, with cylinder deactivation. It's just a tarted-up Chevy Traverse with a bunch of added junk to go wrong. My suggestion, save the cash and buy a Traverse. Modern Cadillacs are absolute piles of E36 M3, I know, I work on them. Every GM dealer around us sold out their Cadillac franchises because they don't want to put up with them anymore
Dead_Sled
Dead_Sled HalfDork
9/15/22 4:34 p.m.
I assume this applies to an AWD 3.0 car as well?  MIL has one, maybe 70k miles.
Off to do some reading
9/15/22 4:45 p.m.
I thought the 2012+ motor had all the "fixes" while the previous were the troubled ones.
9/15/22 5:37 p.m.
If it's longitudinal, the transfer case is sealed and the transmission is sealed and the splined connection between the two is "dry" and semi-exposed to the elements, so it frets unlubricated and rusts and wears the splines out.  In a Volvo this leaves you with front wheel drive.  In a Caddy it leaves you with nothing but neutrals.
Z5NOaW4xlaXOTpzG9pFtBB4SndRIDGbOcKsy3k3p3PODQY6ZTYE8yTyhW4wmlrnF
