Woody
Woody Dork
11/21/08 5:05 p.m.
...the junkyard equivalent of the Lumber Crayon?
Photobucket
I need to get it off without ruining the paint underneath. I've used mineral spirits to remove it from chassis parts, but never from body parts.
Any suggestions?
stuart in mn
stuart in mn Dork
11/21/08 5:42 p.m.
Mineral spirits shouldn't hurt the paint. If you want to get fancy, a can of 3M trim adhesive remover will work as well.
Chebbie_SB
Chebbie_SB HalfDork
11/21/08 5:43 p.m.
Or try "Bug & Tar" remover ?
EastCoastMojo
EastCoastMojo HalfDork
11/21/08 6:02 p.m.
When I read the title I thought this was going to be another Herculiner thread.
44Dwarf
44Dwarf Reader
11/21/08 6:24 p.m.
WD-40 about the only thing it good for....
Carson
Carson Reader
11/21/08 6:29 p.m.
This is the type of thread where someone usually suggests toothpaste.
I'm not suggesting toothpaste, I'll second the "bug and tar"
thatsnowinnebago
thatsnowinnebago Reader
11/21/08 7:12 p.m.
Miata headlight cover?
Woody
Woody Dork
11/21/08 8:02 p.m.
thatsnowinnebago wrote: Miata headlight cover?
Yup.
ArtOfRuin
ArtOfRuin Reader
11/21/08 9:30 p.m.
I still have some of that stuff on my Subaru's windshield from the autocrosses I went to. They put a mark at the top-left corner of the windshiled to indicate my car passed tech inspection. Maybe I'll remove it, someday...
slantvaliant
slantvaliant Reader
11/21/08 9:35 p.m.
Good - no hooti involved.
Sonic
Sonic New Reader
11/21/08 9:39 p.m.
Non acetone nail polish remover. Seriously. I was given that tip by a guy at a high quality junkyard, and it worked great on a door I had for my Integra.
Woody
Woody Dork
11/22/08 8:35 p.m.
I tried WD40 first. I've used it as bug and tar remover and I knew it wouldn't hurt the paint. No luck.
Then I cautiously tried a little bit of mineral spirits. Then a lot of mineral spirits. Still nothing.
Next came compound. Nope.
Finally, with a steady hand, a brand new razor blade and a lot of water, I was able to very carefully scrape it off without damaging the paint. I finished it up with some wet compound.
It came out pretty good, but the next time I'm at the junkyard, I'm going to suggest that they switch brands.
car39
car39 Reader
11/23/08 1:37 p.m.
3M makes a product called prep-sol. It's pretty good at getting off stuff like that. Laquer thinner will also work, if you use it carefully.
Woody
Woody Dork
11/23/08 4:56 p.m.
car39 wrote: 3M makes a product called prep-sol. It's pretty good at getting off stuff like that. Laquer thinner will also work, if you use it carefully.
Tried Prep-Sol.
I was S.O.L.
dean1484
dean1484 HalfDork
11/24/08 5:59 p.m.
I had a can of marking paint go off in the back of my expedition covering the back of the drivers seat with bright orange paint. It got it out with out damage the material.
Worth a try and just good stuff to have in your arsenal of spray cans
Obviously try a small corner first as it may also take the paint off but I would bet a rag with it sprayed in it and a quick wipe would get it.
Salanis
Salanis SuperDork
11/24/08 6:10 p.m.
Shotgun.
porksboy
porksboy HalfDork
11/24/08 6:46 p.m.
Small shaped charge of high explosive?
fiat22turbo
fiat22turbo SuperDork
11/24/08 7:33 p.m.
porksboy wrote: Small shaped charge of high explosive?
Salanis wrote: Shotgun.
Six in one, half a dozen in the other......
benzbaron
benzbaron New Reader
11/24/08 7:44 p.m.
Gasoline is my favorite solvent b/c my bike has an easy source. I've had to scrape the hell out of stuff to get it off my paint before too though. The clay bar takes paint overspray off pretty well without damaging the paint under.
MrJoshua
MrJoshua SuperDork
11/24/08 8:10 p.m.
plastic scraper
Woody
Woody Dork
11/24/08 8:34 p.m.
MrJoshua wrote: plastic scraper
Nope. Tried that too.
j1Npf9UgFSzsFQop8ickqTkjbGR4QMyxWZ7SC07DxyCzn8BLGIM1bBKnr5D104Zz
