frenchyd
frenchyd UltimaDork
10/4/21 4:53 p.m.
Factory redline please.
10/4/21 4:58 p.m.
What does factory redline matter if I don't have factory gears in the trans or rear, or factory tire size?
Is that the redline for the original engine for the car, the redline on the tach, when the engine is at the speed that redline on the tach is marked at, or the redline for the engine that was swapped in?  If it's an amalgamation of parts, can I assume that I am the "factory"?  I have a soft redline of 9500 but have seen 11k in an emergency.  At those levels, the engine drops down to the redline on the tach after a shift.
interestingly, second is still good for roughly the same speed as OE, thanks to all the jiggery pokery.
also interestingly, the tach on every '81-85 RX-7 that I have owned was ten percent off.  7000 indicated (redline) was 6300 actual.
Shadeux
Shadeux Dork
10/4/21 5:09 p.m.
Current car: 73 mph
First car: 104 mph
10/4/21 5:15 p.m.
145 mph or so in first.
aircooled
aircooled MegaDork
10/4/21 5:15 p.m.
My suspicion is that most (stock) ratios will be a bit over 60...
...guess why?
10/4/21 5:18 p.m.
In reply to aircooled :
Lake effect?
(Lake effect is the reason for everything, from odd weather to the Browns accidentally winning a game.)
I recall the STI being "slower" than the WRX some years because 0-60 required two shifts.  Nobody considered the 0-50 or 0-70 times.
And then there was my Quantum that required three shifts to get to 60.  Redline was about a thousand RPM higher than the engine would actually rev at full throttle.  Needless to say, 0-60 was an "eventually" sort of thing.  I think it ran mid-22s in the quarter mile.
New York Nick
New York Nick Reader
10/4/21 5:40 p.m.
62
DeadSkunk  (Warren)
DeadSkunk (Warren) UltimaDork
10/4/21 5:43 p.m.
69-70....R53 MINI Cooper
ShawnG
ShawnG UltimaDork
10/4/21 6:04 p.m.
Faster than it is in 1st gear but not as fast as 3rd gear.
BAMF
BAMF HalfDork
10/4/21 6:14 p.m.
My Volt only has 1 gear and tops out around 100 mph. So if it had another gear...
Javelin (Forum Supporter)
Javelin (Forum Supporter) MegaDork
10/4/21 6:25 p.m.
GPS and Track Addict verified 78 MPH on an SCCA National Tour course.
Feedyurhed
Feedyurhed UltraDork
10/4/21 6:45 p.m.
3rd is the best.
Toyman01 + Sized and
Toyman01 + Sized and MegaDork
10/4/21 7:03 p.m.
I had a 67 Impala that would run somewhere around 125. It only had 2 gears.
Streetwiseguy
Streetwiseguy MegaDork
10/4/21 7:12 p.m.
That is exactly, word for word, my story.  My 67 was a 4door hardtop...
10/4/21 7:14 p.m.
In reply to Streetwiseguy :
Mine was too.
AnthonyGS (Forum Supporter)
AnthonyGS (Forum Supporter) SuperDork
10/4/21 7:44 p.m.
In reply to frenchyd :
Which one?  You think most people here have just one car......
buzzboy
buzzboy Dork
10/4/21 7:54 p.m.
BMW is 73mph at 7200rpms and it's done that many times
Jeep is 60mph at 5000rpms and it's never been close to that
Tom1200
Tom1200 UltraDork
10/4/21 8:00 p.m.
Datsun - 56 mph at 8000 rpm.
Formula 500  - 135 mph becuase it doesn't have a gearbox.
frenchyd
frenchyd UltimaDork
10/4/21 8:16 p.m.
Which Teasla do you have again?
Opti
Opti Dork
10/4/21 8:23 p.m.
79 @ 6500
frenchyd
frenchyd UltimaDork
10/4/21 8:27 p.m.
Fair enough, which ever one you'd like.
Streetwiseguy
10/4/21 8:36 p.m.
In reply to Toyman01 + Sized and :
Metallic green with a black vinyl roof.  283, so the 125 might be a bit optimistic. Let's say 110.
10/4/21 8:45 p.m.
Mine was white on white with the 327.
67LS1
67LS1 Reader
10/4/21 8:56 p.m.
73 mph
Based on a 6800 rpm redline, 2.37 ratio 2nd gear, 3.07 rear end and 26.6" tall tires.
barefootskater (Shaun)
barefootskater (Shaun) PowerDork
10/4/21 9:23 p.m.
Last car I knew this answer for was my S10. 55 in second if I was being abusive. The 4.3 made good tq, but it wasn't much for high rpm. the old duratec zx3 would do close to 65. I'm thinking the Mercury would be quite high but it has no tach and I'm not about to guess when the plugs are about to eject.
optmFTFybS4c0SXiOhAMtSW5KDTn5eCyoTytgC35UFMOH4UNcr0iCI6SukgZF4WT
