Depends on how many bolts you want to break.
Spray everything down with penetrating lube now if you can.
Mine took me 2 hours or so on my first ever try.
depends on how careful you want to be... things speed up a lot when you don't care how many fluids spill on the ground and when you cut wires and hoses instead of properly removing them...
I like to undo the subframe and lift the body away from it. Works well and is reasonably quick if you have the means to lift the body.
I did it in 45 minutes working solo and without cutting anything. I wasn't going for speed, I just knew where everything is and what tools to use. Kinda shocked me when I looked at the clock.
That was with a lift, which certainly speeds things up underneath.
