markwemple
markwemple UberDork
5/27/18 6:00 p.m.
Trying to free up some bolts on the Duc. Using mapp gas to no effect. I don't own a oxy-acetylene set up but it may be time???
RevRico
RevRico UberDork
5/27/18 6:02 p.m.
Make them glow with map torch, then put a candle on the threads you can get to. Seriously, I've freed up 30 year rusted in PA bolts with a candle and torch.
markwemple
markwemple UberDork
5/27/18 6:05 p.m.
Candle....hmmmm... new one. I'll give it a try.Thanks!
TRoglodyte
TRoglodyte UltraDork
5/27/18 6:07 p.m.
If the candle doesn't  work I have used heat and weasel pee
markwemple
markwemple UberDork
5/27/18 6:38 p.m.
I don't own a weasel
TRoglodyte
5/27/18 6:47 p.m.
Acetone and ATF
BrokenYugo
BrokenYugo MegaDork
5/27/18 7:28 p.m.
Depends what they're threaded into/holding together. Gotta be careful with aluminum, mag, any heat treated steels, high grade hardware you need to reuse, etc. A little heat (say 250-300f), your penetrating oil flavor of choice, tapping with a hammer, more oil, more tapping, and waiting a day or three is the better method if you have the time. Best to use a breaker bar, not for the torque, but for the ability to easily work the fastener back and forth, that back and forth twisting often works them free.
Donebrokeit
Donebrokeit SuperDork
5/27/18 9:16 p.m.
Mark, I have found find steady heat over time seems to help the most. If you don't have a weasel try heating it and adding PB Blaster and reapply heat, a few taps with a small hammer can also help.
markwemple
markwemple UberDork
5/28/18 7:36 a.m.
That's what I've been doing. I have to buy acetone and a candle to try those techniques.
NOHOME UltimaDork
5/28/18 8:36 a.m.
Acetone and ATF has been a pleasant surprise  to the point where  keep a bottle on the shelf. No idea why this is not bottled and sold under some brand-name?
The candle does have some scientific validity. The candle is made of paraffin that acts as a lubricant and solvent. The cold paraffin causes a slight vacuum from the the threaded "space" that is maintained by the ( relatively) viscous nature of the paraffin, and hence the paraffin gets sucked in as the fastener cools.
I find that patience is also a big part of the equation.
Pete
markwemple
markwemple UberDork
5/28/18 5:20 p.m.
Got the 2 bolts for the kickstand out. The rear motor mount bolt - snapped the head off. Now I need to drill and tap that one. Oh yeah. Can't even do a e-z out as it needs to turn in, not out.
w1OPyNclNsmU89GRkcGSOWUdh9pUAUCLGq8xakV0EPvvawR4jivellrFNILBu86f
