Evanuel9
Evanuel9 HalfDork
1/14/25 12:26 a.m.
I recently did a valve adjustment on my e30 and when I closed the cover back up, the valve cover stud stripped right out of the head. I barely had to turn the nut and in fact I was able to just lift it out of the hole.
After a bunch of research I decided I would drill it out, tap it, and insert a helicoil insert. After running around to parts store to get the inserts, drill bit, and drill guide block I got back to realize that the engine hoist bracket wouldn't allow me to get my drill in. I pulled the distributor and rotated the bracket out of the way to realize my drill guide block wouldn't fit with the intake manifold and rocker shaft caps in the way.
I cut down the guide block, chucked up my bit, and drilled as straight a hole as I could. I then tapped it and when I inserted the insert the tang wouldnt break off. Then the insert tool got stuck and completely mangled in the hole. I eventually got it out however, and the stud went in. Except it didn't really turn to that high torque - it still felt loose.
Not wanting to strip it again I called it a day, and went to put the cover on. But the stud was too angled to allow the cover on and I had to force it - completely improper way to do it but I was low on time and knackered. I got it on and torque as tight as I dared (can't really fit a torque wrench in there).
I am honestly at a loss of what to do. this is the most recent work I've done on the car and now I'm back at university but I want to find a solution before spring break so I can fix it.
The only solution I can think of is to drill it even bigger and the only way I can think of to keep the bit straight is machining my own L-shaped drill guide that clamps onto the other valve cover studs on either side of it. But I still would have to remove the insert, drill an even *bigger* hole with a bigger helicoil, and take all the risk of mucking it up again.
I could really use some advice because I'm completely out of my depth, and almost at the point of taking it to a mechanic.
jfryjfry
jfryjfry UltraDork
1/14/25 1:20 a.m.
I'd say if it isn't leaking, just run it. Although I like things fixed properly and it does sound like you'd need to remove the insert, re-drill it straight and larger, and then re-coil or timesert it.
1/14/25 6:01 a.m.
Oval the hole in the valve cover a little. Or bend the stud a little.  Or just force it over, it'll be fine.
The guide block was probably the reason it went crooked.  If you're drilling an existing hole, the drill bit will tend to follow that hole.  If you use a guide block, the drill bit will follow the block.  I never use anything like that for helicoiling...
stuart in mn
stuart in mn MegaDork
1/14/25 8:00 a.m.
Yeah, if there aren't any leaks (or even if there is a leak but it's minor), run it as is.  It's not perfect by any means but it works.
CyberEric
CyberEric SuperDork
1/14/25 11:20 a.m.
Wow, I'm feeling a lot of empathy for you, this kind of thing drives me crazy!
Toyman!
Toyman! MegaDork
1/14/25 11:31 a.m.
If it ain't broke, don't fix it.
Is it leaking? If not, run it.
Mattk
Mattk New Reader
1/14/25 11:32 a.m.
I have zero advice for you. But I wanted to mention I respect you digging in and trying to fix these problems yourself. Good for you and good luck on the repair.
Mattk
Mattk New Reader
1/14/25 11:32 a.m.
rtTGsZ2WgERStcdJZZ1ckTfm66dYzFPmM4xFzWwKP5y9ponjAXvkdJmk8YuOIr2n
