sporqster
sporqster Reader
6/26/13 3:31 p.m.
Could someone suggest a cheap way to use up a stockpile of 245-45/17 rims with a '90 325i? I was hoping there would be some OEM rim out there that could get the job done without having to buy new aftermarket rims. Looking for a chumpcar class rim, which means cheap to buy, cheap to replace.
yamaha
yamaha UberDork
6/26/13 3:40 p.m.
Are the tires worth a crap? Because IDK of any 4 lug 17" bmw wheel wide enough. If you had 5x120 pattern, there would be E36 M3loads of wheels for cheap to use.
z31maniac
z31maniac PowerDork
6/26/13 4:24 p.m.
^The APEX racing 17x8 if they are still making them.
But that diameter means lots of ride height AND murdering the fenders. 245/40/17 is a TIGHT fit with rolled fenders and lots of spring rate.
sporqster
sporqster Reader
6/26/13 4:56 p.m.
In reply to z31maniac:
Don't mind rolling, cutting, doing what it takes because race car.
Vigo UltraDork
6/26/13 5:06 p.m.
That tire size is way too damn tall for the car. I have bigger cars than e30s that i still wont put a tire that tall on.
novaderrik
novaderrik UberDork
6/26/13 6:12 p.m.
and
with some
to cover the sharp edges... it's available in different colors if appearance matters..
Giant Purple Snorklewacker
6/26/13 6:44 p.m.
see the e30 in my avatar. every tire fits. you need to change the gearing though - 245/45 is way tall and if you are using a getrag 260 you want to be around a 433 to get past the overdrive. unless auto x. but you said race car ;-)
GjBFQLccOUc4SRbMWu3EIU1MIOT2SolOI6YKjUGoiISwWMz5VyJdLxSNueK00iYt
