Our junkyard transmission for our Lemons car scratches third gear. It isn't in the budget to replace, without cheating, and I want to face the judgement with a clean conscious.
So we filled it with new honda gear oil. Drove it three miles and drained it. It came out looking like a mixture of motor oil and JB weld. Put redline heavy shockproof in it and got it hot yesterday. A rev-match double clutched downshift to third is fine. A second to third upshift still grinds.
If I ease it from second to third I get a soft griiiiind, thunk. If I shift it with some authority by revving it out in second, shifting to neutral, clutch out, clutch in and pushing it hard to third, no grind...just the thunk.
Which upshift method for the longest service life?
Don't shift? Or better yet, cheat. Everyone else does.
We drive a Honda, which isn't cool enough to get away with cheatonium in Lemons. Not as bad as an E30, but still..
We run a Civic. A bottle of Crown for the judges does a good job of "getting away with it."
Javelin
SuperDork
4/21/11 10:12 p.m.
Skip 3 and use 2 and 4. You're not going to need the valves in the engine anyways.
Just swap the transmission and dont say anything? From what i understand everyone else cheats, and why spend all that money to blow the transmission up an 20 minutes into the race? Or, bring a spare and swap it when the first one explodes?
What kind of transmission?
I think you could probably find another trans that needs work or a less-desirable geared model and swap what you need inside them.
How much budget do you have left?
We have a spare dx mystery transmission. Might be worth the time to try it out. What is this Crown you speak of? This is the South. Bribes come in Mason jars.
tuna55
SuperDork
4/22/11 6:52 a.m.
Hey now, the cheating comments are a bit much.
Honestly, we changed ours in practice with another free spare, so n big deal there. Either find a free spare or don't use third. It might just be the syncro going, in that case, change the fluid enough times and stop using it.
RossD
Dork
4/22/11 6:57 a.m.
Can you buy a whole transmission and use only the syncro and the corresponding dollar amount in your budget?
KATYB
Reader
4/22/11 7:37 a.m.
it shouldnt be much to just buy a syncro for it.
Yeah... just swap in another or fix the trans you have with the guts from a donor. The one you have will E36 M3 bits into the the other gears and eat itself. That will be fun for nobody. If your conscience won't allow it ahead of time - agree that it needs replacing as soon as you take it off the trailer. A working 3rd gear isn't a "performance enhancement" its a necessary part to have forward motion- especially at the low speeds a Lemons event runs. You cannot stay in 4th all day.
I drove a Ford Aspire without 4th for a year and a half. It was fine!
You can ask JB about that!
At NJMP, in the Civic wagovan, we used 3rd for precisely one turn on the course. All other turns and the straights were done in 4th.
CMP is a 2-3 track. Some of the turns are painful.
Double clutch the upshift?
KATYB
Reader
4/22/11 5:36 p.m.
he was saying even double clutching and rev matching doesnt help. the syncro is shot. replace the one syncro. and be happy.
Hewlands don't have upshift or downshift synchros--no synchros at all; drive it right, and it lasts for many, many races--years, even. Learn to drive it better.
Rev matchting and double clutching not working? Technique/execution is wrong, or, there is something else wrong with the trans rattling around in it.
Final analysis, grinding equals making savings, which eats away at the other internals, so, go with the grind free technique--and hope for rain!
Really? That sucks.
However, I think this is a different situation. Run it till it dies, then replace it with the cheapest one you can find. But run it till it dies first, that's the point of lemons.
Old transmissions with crunchy shifts will go a long ways. Believe me, if you have never run LeMons before a scrape going into 3rd will be the least of your worries. If you are really worried about the scrape/crunch/grind, run the cheapest oil you can find. Why?
A synchronizer depends on friction to make it work. 'Iffy' synchros will work worse with good oil because the synchro can't slow the mechanisms down to match the speeds. Honda boxes should run 20w50 motor oil. Run something a bit less slippery (cheap 90 wt or similar, stay away from Red Line etc) and see how that does.
My suggestion: run cheap sticky lube, bang shift the original box (shift it like you mean it, not like you are going grocery shopping) and bring a spare just in case.
I dont get it. It is not like the trannies are marked or sealed. Just buy a used trannie and swap them out. Just dont advertise it. I am also sure that there is probably someone out there who can rebuild the trannie and make it last. ISC was my saviour with the RX3. We could swap out a trans in 90 min at the track and after paying Mike for a rebuild, I never had to use that experience again.
We're just going to use it and bring a spare. This will be my fourth Lemons event, but first time with this car.
