ls1fiero
ls1fiero Reader
2/22/14 8:15 a.m.
I use the ATV for everything from moving the tow dolly to pulling cars to playing in the snow. The steer tires are shot so I ordered up a new pair. I have tried everything but the chainsaw to get the old ones dismounted. May try that next unless ye GRM world has suggestions.
JohnRW1621
JohnRW1621 UltimaDork
2/22/14 8:22 a.m.
This seems like the right place for this...
Shotgun?
patgizz
patgizz UberDork
2/22/14 8:34 a.m.
cutoff wheel. split rim, throw away, install 2 piece rims.
thats what i did with mine after fighting for them for hours with tire irons.
oldopelguy
oldopelguy SuperDork
2/22/14 9:20 a.m.
Remove valve core, jack up on wheel on truck, set atv tire on its side under truck wheel, lower truck onto atv tire?
mw
mw Dork
2/22/14 10:17 a.m.
bead breaker?
pjbgravely
pjbgravely New Reader
2/22/14 11:05 a.m.
Are you trying to break the bead? I use an old crank bumper jack. A ratchet one will work too. There are hand small wheel bead breakers you can buy. 4 tire irons and some help will get the tire off the rim
I had one set of very old tires that wouldn't come off of split rims. I had to burn them off. I do have a chainsaw set up to cut tires.
motomoron
motomoron SuperDork
2/22/14 11:21 p.m.
I made a ghetto bead breaker out of a length of 4x4 with a bolted on wedge, also made of 4x4 on the bottom. Stick one end under a truck, the wheel/tire under the wedge, push down, pop.
Then lube it up w/ KY jelly (seriously, I demounted and mounted scores of motorcycle and kart tires w/ KY)and lever it off. One of the tiny handful of genuinely good Harbor Fright tools are their huge-ass tire levers. Big tire levers are like big hammers; used correctly they do the job in one economical motion and are in reality ~less~ likely to damage things than flailing at the wheel w/ small ones.
xgNAzCUL2cF9Vgv6d48rdRDcAK4he7iUPKAjD7VfeE1taRfpXikWu6QXwXneqV4D
