Gearheadotaku
Gearheadotaku PowerDork
10/22/15 9:09 p.m.
Swapping out the steering column in my 2000 Firebird tomarrow. Whats the best way to remove then reinstall the airbag? Just unplug? pull fuse? unhook battery?
mad_machine
mad_machine MegaDork
10/22/15 9:15 p.m.
I always just carefully unplugged them. Remember though, treat them like the bomb they are.
Ranger50
Ranger50 PowerDork
10/22/15 9:15 p.m.
Don't be a dumbass and it's all good. I have yet to do any of the sort and probably jinxing myself but never had one go off yet.
mazdeuce
mazdeuce PowerDork
10/22/15 9:32 p.m.
There is a line of fire. Stay out of it just in case.
Tom_Spangler
Tom_Spangler UltraDork
10/22/15 9:44 p.m.
I did it in my Miata and E36. I disconnected the battery, then carefully unplugged the airbag connector while staying clear of the path of the bag. I then very gently removed it and placed it on a bench far away from me.
It is a bomb. Don't forget that and you'll be fine.
bgkast
bgkast UberDork
10/22/15 9:50 p.m.
I always disconnect the battery and step on the brakes for a second to use the brake lights to discharge any remaining voltage before disconnecting an airbag.
fiesta54
fiesta54 Reader
10/22/15 9:57 p.m.
Yea i disconnect the battery and usually give it a few minutes to kill any back up batteries they have
flatlander937
flatlander937 Reader
10/22/15 10:49 p.m.
Technically you should disconnect the battery then do something to make sure all is discharged(wait 3+ min, turn on lights, etc).
In reality I've rarely done that. Probably removed/reinstalled 100+ airbags.
Think about it: they need power and ground to go off. They're not getting power from the SRS module unless you hit something/etc while moving X mph. Don't stuff a horn wire on the terminals and you should be good.
For liability reasons I advise you should disconnect the battery. Do as I say, not as I do.
Kenny_McCormic
Kenny_McCormic UltimaDork
10/23/15 1:34 a.m.
Read the disarm procedure in the FSM? I just unplug them but I couldn't recommend that to somebody else.
novaderrik
novaderrik UltimaDork
10/23/15 1:54 a.m.
i just unbolt them, pull them out, and unplug them... it aint going off unless the system sends voltage to it, and the odds of that happening with the key off is close enough to zero to not worry about it..
i took the airbag out of my Neon apart just to see how they are built... kind of cool...
Wall-e
Wall-e MegaDork
10/23/15 2:02 a.m.
Hum the Mission Impossible them song and ponder how to unplug it for a minute or two to be sure.
RossD
RossD UltimaDork
10/23/15 8:05 a.m.
Ghost ride it into a concrete embankment.
alfadriver
alfadriver UltimaDork
10/23/15 8:16 a.m.
Wall-e wrote: Hum the Mission Impossible them song and ponder how to unplug it for a minute or two to be sure.
Cut the green wire or the red wire?
What if the wires have two colors?
10/23/15 8:26 a.m.
Make sure the battery is not connected while removing OR installing the air bag!
Run_Away
Run_Away Reader
10/23/15 8:29 a.m.
Don't shuffle your feet on carpet before touching the connector.
Grtechguy
Grtechguy UltimaDork
10/23/15 8:36 a.m.
Hit the sensor with a hammer? No worries after that.
iceracer
iceracer PowerDork
10/23/15 11:10 a.m.
Once they are unplugged they are pretty safe.
Rusted_Busted_Spit
Rusted_Busted_Spit UberDork
10/23/15 12:18 p.m.
With the battery disconnected you should be fine, though I did swap a steering wheel with the battery connected but I was younger and dumber at the time.
LuxInterior
LuxInterior Reader
10/23/15 4:53 p.m.
  1. Remove carefully
  2. Remember NOT to put it in the microwave
haYw1OydVLMOZa3s6vBlxx6JqD0bTdoG1zMDRZkMO2Yp9KRxhu6FpEQflG56GU9L
