ThePhranc
ThePhranc HalfDork
2/26/12 6:42 p.m.
As much as I like manual steering a 20:1 turn ratio sucks. Today the assend broke loose on me and I came to the conclusion that it took to much to turning to correct and thats not safe for me. So in looking up the best power steering boxes I saw something about hydroboost brakes. From what I gather its vacuumless boosted by plumbing into the power steering pump. Is it really that easy and what did these come in besides Asto vans? How available are parts? Can I score these at junkyards? Also with the power steering box and brakes tag teaming the pump would a fluid cooler be needed?
JThw8
JThw8 SuperDork
2/26/12 6:47 p.m.
Chevy used them in a lot of larger trucks. I'm pretty sure the BMW units are sought after as conversion pieces for a lot of other cars.
I've had the trucks with them, its a good setup, takes up less space than a vacuum booster. Parts can be a bit pricey if you get them at the store but can be junkyard found. Any system I've seen had a small cooler on it.
mad_machine
mad_machine SuperDork
2/26/12 6:53 p.m.
I seem to recall a friend's olds Toranado had hydroboost too?
ThePhranc
ThePhranc HalfDork
2/26/12 6:57 p.m.
JThw8 wrote: Chevy used them in a lot of larger trucks. I'm pretty sure the BMW units are sought after as conversion pieces for a lot of other cars. I've had the trucks with them, its a good setup, takes up less space than a vacuum booster. Parts can be a bit pricey if you get them at the store but can be junkyard found. Any system I've seen had a small cooler on it.
When you say larger trucks do you mean GM 3500 or bigger than that?
ronbros
ronbros Reader
2/26/12 6:58 p.m.
i have Hydroboost brakes on my Buick Grand National, converted 2002 camaro rotors,calipers,, carbon pads,, Wilwood M/C.
for an old buick it stops with little pressure, and straight arrow, you cant make them fade.
a great system!
Ranger50
Ranger50 Dork
2/26/12 7:10 p.m.
Mustangs with a 4.6. Common as dirt and priced about the same.
patgizz
patgizz SuperDork
2/26/12 7:12 p.m.
my 90 3500 has them as did my 76 c30 and all my astros.
i'm going to convert my 68 c20 to hydroboost once i pick up a power steering box. it'll knock out power brakes and steering in one.
also had an 83 mark VII with it.
stuart in mn
stuart in mn SuperDork
2/26/12 7:17 p.m.
Some older BMWs used a hydroboost system.
1980-1992 BMW 7-series
1983-1992 BMW 533i and 535i
1982-1989 BMW 6-series
Keith
Keith SuperDork
2/26/12 7:21 p.m.
How else would you put power brakes on a diesel? Can't exactly use engine vacuum. I'm pretty sure my Dodge has 'em.
1988RedT2
1988RedT2 SuperDork
2/26/12 7:24 p.m.
My 1985 Chevy C30 Dooley has hydroboost brakes, FWIW.
ThePhranc
ThePhranc HalfDork
2/26/12 7:29 p.m.
Keith wrote: How else would you put power brakes on a diesel? Can't exactly use engine vacuum. I'm pretty sure my Dodge has 'em.
Vacuum pump :)
oldtin
oldtin SuperDork
2/26/12 7:35 p.m.
70s big mercurys, big ford wagons, lincolns (some newer town cars), some cadillacs, diesel pickups, some astro vans, newer mustang gt/cobras, dodge ram 2500s & up...failure points are usually O-rings - easy to fix. The older ones are SAE threaded masters, newer ones are metric - buy to match your power steering pump otherwise it will cost you about $70 in high pressure hoses/fittings.
JFX001
JFX001 SuperDork
2/26/12 7:49 p.m.
Just to give you an idea:
http://www.jamesduff.com/eb/booster.html
I think all of the hydroboost EB stuff started with a 70's Lincoln.
ThePhranc
ThePhranc HalfDork
2/26/12 7:55 p.m.
I think I'll look for something with the hydrobosst, sagnaw 12:1 power steering box and pump all in one car. Time to cross reference the holy hell out of rockauto.
Ranger50
Ranger50 Dork
2/26/12 8:21 p.m.
Vacuum pump :)
+1. I've replaced that POFS on my Ford twice.
novaderrik
novaderrik SuperDork
2/27/12 1:58 a.m.
i love the hydraboost in my 84 Regal T Type. it leaked for a few years before i found a place that sells a rebuild kit- www.piratejack.net - which was pretty easy to install since there really aren't that many moving parts in there.
if we are talking a GM vehicle here, then look under the hoods of any diesel powered vehicle- pickups, early 80's Cutlasses, etc- and some luxury cars from the 70's and 80's like El Dorados.. then there are the AWD Astro vans, obviously.
Wally
Wally SuperDork
2/27/12 2:57 a.m.
ronbros wrote: i have Hydroboost brakes on my Buick Grand National, converted 2002 camaro rotors,calipers,, carbon pads,, Wilwood M/C. for an old buick it stops with little pressure, and straight arrow, you cant make them fade. a great system!
What did you use to mount the brakes to the spindle? I'm trying to decide what to do for brakes on my Monte Carlo.
novaderrik
2/27/12 4:23 a.m.
you cut off the stock caliper mounting bosses and drill and tap the caliper mounting holes on the spindle to a larger size and make a simple bracket out of 1/4" steel that uses the stock caliper mounting holes on the spindle to mount the Camaro/Vette/whatever caliper mounting bracket to hold the caliper over the rotor.. if you don't know how to drill 4 holes in a piece of steel, there is always the option of buying the adapter brackets from a place like Kore3 for something like $75 for the pair.
44Dwarf
44Dwarf Dork
2/27/12 6:48 a.m.
http://www.scarebird.com/index.php?id=1
This guy sells all sorts of disk conversions all using stock off self stuff except his brackets.
patgizz
patgizz SuperDork
2/27/12 11:54 a.m.
and i could never recommend his parts to anyone after the sorry experience i had with him.
gFlYAlNbsUJYR9sylebdTApUkBAlvej37fPhSbTJOvBV23iqyowieolQ5ZzW8GMP
