yamaha
yamaha UltimaDork
4/9/14 12:21 p.m.
In reply to Leafy:
If you're dealing with sub 4" tubing alot, you haven't found the easy button yet if you don't own a portaband saw.....
GregW1
GregW1 New Reader
4/12/14 8:44 a.m.
Live on Raman noodles and water for a few weeks and you will save more weight than most any amount of cutting and grinding.
Basil Exposition
Basil Exposition Dork
4/12/14 12:50 p.m.
Just used a air powered die grinder to cut a door crash bar out of my MG Midget. I didn't weigh the debris, but it had to be at least 10 lbs.
codrus
codrus HalfDork
4/12/14 3:41 p.m.
The difficulty I find with a sawzall when trying to cut tubing is that the blade bends, and you don't wind up with a cut that's square. Cutting 1" square tubing in the vise, I wind up with the two top corners on a perpendicular line, but the outside bottom corner is 3-4 mm to the outside of the cut.
This is with a DeWalt saw and Milwaukee blades.
eDXvSdK5FDlmNepU0h3HMjL0sOuP6cZzTEGoGfA1ngfrtMezTAy8bt217mXm13RL
