motomoron
motomoron Dork
4/16/12 10:31 p.m.
What I need is an Ultima Can Am. I could get rid of a whole load of cars and this should cover most of the bases. I'm gonna be all obsessed with this for at least 3 days now.
Prices
DoctorBlade
DoctorBlade Dork
4/16/12 10:43 p.m.
That's one heck of a kit.
m4ff3w
m4ff3w SuperDork
4/16/12 10:59 p.m.
I'll take the GTR instead.
I Am Keyser Söze
I Am Keyser Söze SuperDork
4/16/12 11:01 p.m.
I love the Ultima kit. It is a knock out performer, looks bad ass and is just outright alright.
GameboyRMH UberDork
4/17/12 8:27 a.m.
Great car but it uses a Porsche transaxle...$$$$$
DeadSkunk
DeadSkunk Dork
4/17/12 8:56 a.m.
In reply to motomoron:
If you're in that frame of mind you need to hit the Carlisle Kit Car show. And take your cheque book, too !
bravenrace
bravenrace UberDork
4/17/12 8:58 a.m.
In reply to DeadSkunk:
I take it you've been there? What can you tell us about it? I've been tempted to go a few times, but haven't yet. Think I could sell my TVR there?
jrw1621
jrw1621 PowerDork
4/17/12 9:28 a.m.
Is this your TVR? I have seen it on CL in the past.
http://cleveland.craigslist.org/cto/2947423568.html
Very nice.
nderwater
nderwater UltraDork
4/17/12 9:40 a.m.
I've only ever seen one Ultima, a GTR in suburban Maryland. I thought it was a little underwhelming - it looked just a bit too kit-car instead of exotic (I feel the same way about the FFR GTM and Noble M12). I can't imagine how awesome it would be to drive, though!
I Am Keyser Söze
4/17/12 10:16 a.m.
On the Ultima, I don't like the wheels, I don't know why they insist on those wheels but, ugh.
I don't like the way the headlights look inside. Not the configuration the background behind the lens.
I don't like how the roll hoop looks. It looks like an after thought.
I don't like the Porsche transaxle.
That being said.
I can buy different wheels, paint the area around the head lamps, do a Shelby GT500KR roll bar pad treatment that makes it look more finished and install a different transmission.
So I guess I am just trying to empathize with you on the kit car feel?
WilberM3
WilberM3 Dork
4/17/12 10:34 a.m.
nderwater wrote: I've only ever seen one Ultima, a GTR in suburban Maryland. I thought it was a little underwhelming - it looked just a bit too kit-car instead of exotic (I feel the same way about the FFR GTM and Noble M12). I can't imagine how awesome it would be to drive, though!
I think in the Noble's case it's the giant wing found on nearly all of them. my company built a Rossion Q1 (noble) for a customer who ordered his without the rear wing and it looks FAR classier with nearly identical body lines.
bravenrace
bravenrace UberDork
4/17/12 10:41 a.m.
In reply to jrw1621:
No, that's not mine.
GameboyRMH UberDork
4/17/12 10:49 a.m.
That Noble looks much better without the wing, but it was probably there for a reason...maybe if they put a rear diffuser on there that wasn't just ornamental that could make up for the downforce. I think it would also look much better if the brake cooling inlets weren't so gaping huge, but we're trying to turn an unapologetic track car into a classy supercar...
pres589
pres589 Dork
4/17/12 10:49 a.m.
In reply to I Am Keyser Söze:
Curious what you'd suggest in place of the Porsche trans.
ThePhranc
ThePhranc HalfDork
4/17/12 10:54 a.m.
pres589 wrote: In reply to I Am Keyser Söze: Curious what you'd suggest in place of the Porsche trans.
FF sourced a new trans for the GTM to replace the Porsche ones.
m4ff3w
m4ff3w SuperDork
4/17/12 11:13 a.m.
Audi 01E/01X?
Subaru converted to 2WD?
dculberson
dculberson Dork
4/17/12 12:33 p.m.
ThePhranc wrote: FF sourced a new trans for the GTM to replace the Porsche ones.
When? They still list the Porsche G50 as the transmission you need..
http://www.factoryfive.com/kits/gtm-supercar/what-you-need/
and from
http://www.factoryfive.com/kits/gtm-supercar/faq/
"What type of transmission does the GTM use?
The transmission is a G50 from a 1990-1998 Porsche 911. On average, you can purchase a used/new G50 for between $2,500 – $7,000."
EDT
EDT New Reader
4/17/12 9:49 p.m.
In reply to dculberson:
You now can use a Mendeola transaxle they had designed. You can find it on the Factory Five parts website under drivetrain for the GTM.
m4ff3w
m4ff3w SuperDork
4/17/12 9:57 p.m.
FFR said: This 5 speed gearbox is designed as a bolt in replacement for the required Porsche transaxle in the mid-engine Factory Five GTM. The gearing provides good street manners with 2100 RPM at 65 MPH and a top speed of more than 200 MPH. This allows for a great all around set of gears for street, track duty, and highway fuel economy. The new Factory Five-Mendeola SDR transmission is a good match for Chevrolet's LS engines. The transaxle bolts directly to the LS engine block without using a bell housing adaptor. Features: Limited slip differential 930 drive stubs with 10 x 1.50 bolt holes A356 T6 cast aluminum housing Total weight is 168 lbs. Tremec 26 spline input shaft for LS1/LS6 stock clutch Uses 1998-2008 Corvette/Camaro LS1-LS6 stock 168 tooth flywheel Transmission fluid capacity is 5 quarts Requires: 78-79 Porsche 930 40 mm CV joints For LS1/LS6 - 1998-2008 Corvette/Camaro LS1/LS6 stock clutch (Not Z06) For LS2/LS7 - Use Kennedy 11" Street Pressure Plate (#KEP-GMP11) and Kennedy Organic Clutch Disc 26 spline (#KEP-S11) 1998-2008 Corvette/Camaro LS1-LS6 stock 168 tooth flywheel Hi Torque IMI-140 starter Shipping is $299. THIS IS A CUSTOM DESIGNED PART. PLEASE ALLOW UP TO 12 WEEKS FOR DELIVERY. Click here for installation instructions. Details SKU #26106 Price: $8600.00
poopshovel
poopshovel PowerDork
4/17/12 10:26 p.m.
I will say: I saw two at CMP a couple years ago. I won't split hairs on bang for buck, etc. I will say that multiple parts of my anatomy screamed "berkeley, I NEED TO BE INSIDE THAT!!!"
JFX001
JFX001 UltraDork
4/17/12 10:35 p.m.
If you click the Ultima link above and scroll down to the "ENGINE BAY" section, they can source you a used Getrag 6 speed for 350 pounds over the cost of a G50.
EDIT....I drive one of the Noble's when they first came out...sweet car. Truth be told, I didn't mind the wing....maybe it was the color.
motomoron
motomoron Dork
4/17/12 11:08 p.m.
If I sold the M3, Sprite and Radical, I'd be about there to build a really nice one. That's all I'm saying.
Appleseed PowerDork
4/18/12 3:57 a.m.
I have seen Jeff Schwartz' twin turbo LS7 Ultima in person. That car gives me the stiffest of stiffies.
Raze
Raze SuperDork
4/18/12 7:49 a.m.
You gotta see Jon Olson's Ultima GTR, err Rebellion R1K:
It's a custom body kit he had a maker build that still has the molds for and can build you a set
Luke
Luke UberDork
4/18/12 7:57 a.m.
motomoron wrote: If I sold the M3, Sprite and Radical, I'd be about there to build a really nice one. That's all I'm saying.
I'd rather have those 3 cars.
Would the Ultima provide the same raw, visceral thrill that you (presumably) get from the Radical?
Ehpmivw2hboQpgBefnSIOv07sxrxv4LX8jKOLN1aBoCq48LDsXnyoc3fJvra813h
