tuna55
tuna55 UltimaDork
8/4/14 10:44 p.m.
For the project truck, I find myself with an odd problem. I have two tubes protruding through the wheeltub. I wish to somewhat isolate the large hole in the wheeltub from road debris, but I need the membrane to be easily removable. Basically, I need duct tape that I can form into a membrane that I can rivet onto the wheeltub and not be a hack about it.
Ideas?
Knurled
Knurled PowerDork
8/4/14 10:56 p.m.
Shifter boot?
Kenny_McCormic
Kenny_McCormic PowerDork
8/4/14 11:03 p.m.
A sheet of rubber? The stuff they use for membranes roofing is great if you know any roofers and can get your hands on some scrap.
RossD
RossD PowerDork
8/5/14 7:33 a.m.
Look up 'pipe portal'
Or how about a clamping CV joint boot?
Fueled by Caffeine
Fueled by Caffeine MegaDork
8/5/14 7:52 a.m.
what about a wheelbarrow inner tube?
pinchvalve
pinchvalve MegaDork
8/5/14 7:53 a.m.
Aw crap! I just helped a buddy lay down some roofing membrane. 40 mil thick IIRC. TOUGH STUFF. He had a BUNCH of scrap left over. Give me your sizes and I will see if I can score some pieces.
1988RedT2
1988RedT2 PowerDork
8/5/14 7:59 a.m.
Elephant condom?
Powar
Powar SuperDork
8/5/14 8:00 a.m.
Could you reuse the firewall boot from... something? On my C900s, there is one that surrounds the shifter shaft as it passes through the firewall. It is held in place by the lip on the firewall.
tuna55
tuna55 UltimaDork
8/5/14 8:05 a.m.
I am not sure about any of these yet/ The application is two tubes, one 2 1/4" and one 3/4" protruding through a square hole roughly 5"x4".
Curmudgeon
Curmudgeon MegaDork
8/5/14 8:12 a.m.
Maybe something like these?
http://www.sealsit.com/firewall.asp
tuna55
tuna55 UltimaDork
8/5/14 8:32 a.m.
Curmudgeon wrote: Maybe something like these? http://www.sealsit.com/firewall.asp
Looks good, but pricey. I might DIY something just like it, though.
wvumtnbkr
wvumtnbkr Dork
8/5/14 8:33 a.m.
Mudflap material.
NOHOME SuperDork
8/5/14 8:47 a.m.
Pond liner. And you can mimic what curmudgeon shows with a sheetmetal rings around the perimeter. Cheap and available. The roof membrane will also work.
Since I know $$$ is always a factor, might also be worth looking in the carpet runner section of the Home Depot. Buy it by the foot instead of the roll.
If you need to get real fancy, you can order some liquid casting material and make a mold of what you want. Some of the materials are very tough when cured.
fasted58
fasted58 PowerDork
8/5/14 8:53 a.m.
That roofing material is good stuff, always keep some handy around the shop. 101 uses. Use it under jaw teeth wrench to not mar the surface too.
There's industrial rubber gasket material in rolls/ sheets, some reinforced w/ fiber. 1/8" would be good for that type of application, won't flex as much as roofing material. Somebody in a plant or mill oughta hook ya up.
bluej
bluej SuperDork
8/5/14 9:08 a.m.
Little silicone around the tube to membrane seam helps (Watch yer hootus).
Duke UltimaDork
8/5/14 9:30 a.m.
NOHOME wrote: Pond liner. ... The roof membrane will also work.
Hint: it's pretty much the same stuff.
Go to big box home store of choice and look for pipe boot flashing.
egnorant
egnorant SuperDork
8/5/14 9:31 a.m.
I had a couple of holes that needed isolation and used a plastic trash can as a donor. Easy to cut, molded it a bit with a heat gun, paint and VIOLA...perfect fit. I even put a grommet in it for some wires and hot melted some washers in the screw holes.
I did drag home a couple of roof membrane (Mule Skin) that has become many things such as lower shifter boot.
Bruce
Duke UltimaDork
8/5/14 9:42 a.m.
The roof membrane everybody is talking about is EPDM, by the way. Typically available in 40 mil, 40 mil reinforced, and 60 mil. I'd skip the reinforced stuff.
Driven5
Driven5 HalfDork
8/5/14 9:58 a.m.
How good of a seal do you need? Does it need to be flexible, or is a little freedom of movement enough? Could a solid piece of sheet be cut to fit close on the tube(s) and larger than the hole, then positioned closely against the wheel tub?
Just spitballing ideas, since I am unable to see the application or know what the other requirements and constraints might be.
tuna55
tuna55 UltimaDork
8/5/14 10:12 a.m.
In reply to Driven5:
I just need the cavity above the wheeltub not to be filled with trash and dust. The tubes I am sealing are protruding from under the wheeltub and into a faux stake pocket. I don't want the faux stake pocket to get ridiculously filthy. We're not talking water tight.
The hardest part is that I have to decide to make it reusable or not, because the tubes have a flexible hose on each end to connect them, and the hose will need to be pulled down through this membrane due to space constraints to remove the tube.
Then again, how often do you need to maintain your fuel filler?
JohnRW1621
JohnRW1621 UltimaDork
8/5/14 11:28 a.m.
Curmudgeon
Curmudgeon MegaDork
8/5/14 12:03 p.m.
Price is always an issue for me, cheap is best. Shoot, head to the boneyard and start looking around. Firewall harness grommets for wiring, the aforementioned steering shaft boots, there's all kinds of stuff out there. Something is bound to fit.
fasted58
fasted58 PowerDork
8/5/14 12:30 p.m.
JohnRW1621 wrote: Insane
and that's why I can't say membrane
thanks, now stuck in my brain all day
8/5/14 4:07 p.m.
Here, this will help:
MrJoshua
MrJoshua PowerDork
8/5/14 4:59 p.m.
Doesn't the Miata have something like this where the fuel tank fill and vent penetrate the trunk floor?
I'm fresh out of miatae or I would just look.
8XaYlsj4oBWxSr92Qc9ogBD8D4nfqVxq4fonjaJhE0nqMN8L1HFpPZpW2P9KFBlV
