m4ff3w
m4ff3w SuperDork
5/7/12 11:46 a.m.
I'm getting closer to gettin the BiTrouble's engine in. Once in, I need to wire up MSII and connect the fuel supply. Since my car was originally carb - the fuel system needs to be changed. Luckily the FPR on there has a return.
I need assistance find a FPR. I'm not going to go out and spend $100+ on an Aeromotive FPR. The cash just isn't there. Ideally I can find a cheap OEM FPR to use.
That is the OEM EFI setup. I don't have the FPR or the hoses that go form the fuel rail fitting to the FPR.
First, the factory FPR has two inlets on it - I don't see a technical reason why I couldn't Tee the lines coming off the Fuel rail and use a more conventional FPR - anyone have a differing opinion?
Second, does anyone know of an OEM FPR that uses hose barbs - I need to convert from the -4 fitting.
Third, has anyone used those cheap FPR on eBay - the "0-140 PSI with gauge" - I think I'd rather use an OEM one though.
Fourth, anyone have any other suggestions? Sorry if I'm rambling - running on a couple of hours of sleep.
Ian F
Ian F UberDork
5/7/12 11:53 a.m.
I've heard of guys using a Nisson FPR when MS'ing classic Volvos' It's a little different being an I-4. Does it have to be a 4-port and can the output port be replaced with a T fitting?
92CelicaHalfTrac
92CelicaHalfTrac MegaDork
5/7/12 11:54 a.m.
Would a very slightly used $85 Aeromotive be acceptable?
I've used the Ebay ones before and my car didn't burn to the ground.
m4ff3w
m4ff3w SuperDork
5/7/12 11:59 a.m.
92CelicaHalfTrac wrote: Would a very slightly used $85 Aeromotive be acceptable? I've used the Ebay ones before and my car didn't burn to the ground.
Sadly even $85 is out of my budget. The $25-$30 ebay ones are probably my choice for new - unless I can find an OEM one at PnP I can get for $1.
92CelicaHalfTrac
5/7/12 12:01 p.m.
Is the OEM regulator static or does it go up a bit with boost?
m4ff3w
m4ff3w SuperDork
5/7/12 12:16 p.m.
92CelicaHalfTrac wrote: Is the OEM regulator static or does it go up a bit with boost?
The rate is static. I've confused myself talking about FPR with people before (or they've confused me)
Fuel pressure is always X psi above manifold pressure. X psi is constant. Not like an old rising rate FPR.
92CelicaHalfTrac
5/7/12 12:25 p.m.
The rate is static. I've confused myself talking about FPR with people before (or they've confused me) Fuel pressure is always X psi above manifold pressure. X psi is constant. Not like an old rising rate FPR.
Ok so it's static base pressure, rising at 1:1 with manifold pressure.
That should give you something to look for in the junkyards. I know the FPR on the 88-92 turbo MX6/Probes is the same way, but you might run into flange issues. It mounts directly into the fuel rail.
m4ff3w
m4ff3w SuperDork
5/7/12 12:33 p.m.
Yea, thats my big issue. I need to find something that has hose barbs. But if you've had success with an eBay one - I may go that route.
92CelicaHalfTrac
5/7/12 12:41 p.m.
m4ff3w wrote: Yea, thats my big issue. I need to find something that has hose barbs. But if you've had success with an eBay one - I may go that route.
That's probably your only hope of finding something that will work on a short notice.
I have a spare KL unit, but again, that mounts directly into the rail.
ditchdigger
ditchdigger Dork
5/7/12 2:09 p.m.
Dodge 2.2 turbo
Should be easily junkyardable I would think.
turboswede
turboswede PowerDork
5/7/12 3:42 p.m.
Volvo used a similar one. Pretty standard Bosch unit. Volvo runs at 45psi.
Dodge runs at 55psi.
Both rise at 1:1 ratio based on pressure in the intake.
MG Bryan
MG Bryan SuperDork
5/7/12 3:45 p.m.
The wealth of knowledge here continues to astound me.
m4ff3w
m4ff3w SuperDork
5/7/12 3:55 p.m.
turboswede wrote: Volvo used a similar one. Pretty standard Bosch unit. Volvo runs at 45psi. Dodge runs at 55psi. Both rise at 1:1 ratio based on pressure in the intake.
Don't all the Volvo ones bolt to the fuel rail with an o-ring?
jzn3PvNqIFiZWua7fvF30xRMYqmOdrJLDBH1OoWdPLwN7CTzcf1cX4luKvFJq9n7
