Gaunt596
Gaunt596 Reader
11/30/18 10:45 p.m.
Need a sanity check here. I purchased an Eagle MTP-12C 12k rated, two post lift for the new garage a while back. chinglish instructions aside, i have it mostly together, and when i went to lower the lift from where its at (third or fourth locking position) to the floor, so i could lift it to the correct lock set and set the cable tension, the left side post wont lower at all. it dropped about an inch or so, and then refuses to lower any further. the right side post goes all the way to the floor with no issues. i havent applied any power to the lift, nor have any hydraulic fluid in any lines/cylinders, the lift is a direct drive with single acting lift cylinders, so they should raise/lower fine without fluid. ive checked and made sure the post is plumb, and the carriage itself isnt getting hung up on anything or binding.i made sure the safety locks were fully disengaged, and pinned them so they cant lock at all. ive removed the bleed screw at the top as well as cracked the banjo fitting at the bottom, neither of which allowed the cylinder to lower, and the lines running from one side to the other are not connected yet. i have also loosened/removed the synchronizing cables, just to be sure they weren't creating an issue . im not sure where to go from here, im planning on calling eagle on monday to see if they have any ideas, but given how terrible the instructions are, or lack thereof, im not expecting much help. am i right in thinking the hydraulic cylinder is getting hung up on something internal, or possibly bent? i think ive just about ruled out everything else. and its only the left side post, the right side post can be lifted and lowered all the way by itself just fine.
Apexcarver
Apexcarver UltimaDork
11/30/18 11:32 p.m.
Put any weight on it? Without fluid lubricating, it might need it.
Gaunt596
Gaunt596 Reader
12/1/18 8:38 a.m.
Yes. I've stood my 235lb self on it, as well as my 300lb father on it at the same time, to no effect.
Brotus7
Brotus7 HalfDork
12/1/18 10:26 a.m.
Can you lift it a little, then watch it carefully as you try to drop it?  Sounds like it's catching on something, like a misaligned bearing, excessive play allowing it to bind or some such.  If that's the case, you might catch a glimpse of it rocking just as it gets bound up - that'd tell you where to look.
Gaunt596
Gaunt596 Reader
12/1/18 12:37 p.m.
Did that, didn't see anything obvious hanging it up, and I checked the top side slider blocks too
5lOz3pQC1m4oOROfO9VCho6qVmXtUvZEzaTMHansv2IGCzXaoIQ6aMPvp3fMFpdv
