CivicSiRacer
CivicSiRacer Reader
4/29/09 12:56 p.m.
Don't know if you guys have a Grassroots way of fixing this before I have to shell out money.
I have a 93 Civic Si with 230,000 miles. Last week had the head gasket replaced. Afterwards took the car out for a drive and the car was bogging and almost stalled a couple times.
Took it back to Honda and they tried to fix the timing and found the ICV (Idle Control Valve) is sticking open and shut. New part is $200 including labor. They say if that is replaced my idling and bogging should go away.
Does anyone know a fix for this? I'm skeptical about buying one off Ebay, and some friends recommend buying new. I just spent $$$ on head gasket and new clutch and wife wants to kill me if I put anymore money in
Right now it will idle high (1200-1400 rpms) when warm, turn AC on it will drop to well below 500rpms. Sometimes it will idle normally around 700rpms. Around 2000-3000 rpms will be a slight bog and then accelerate again.
I cleaned it with Carb cleaner year ago or so.
internetautomart
internetautomart SuperDork
4/29/09 1:17 p.m.
on some cars you can clean the IAC with some carb cleaner.
My suggestion is to disassemble it and clean it thoroughly then reassemble and reseal it.
Nashco
Nashco SuperDork
4/29/09 1:33 p.m.
As said, they can usually be cleaned to free them up. Give it a shot again, it might only buy you another 6-12 months, but if you're trying to avoid buying a new one that's the tradeoff. Meanwhile, go to the junkyard and get another used one for $10. Clean it and when it starts acting up again, it's a ten minute job to swap it out and you can clean the other one when you get around to it.
Cheap, fast, and easy. Pick two.
Bryce
Grtechguy
Grtechguy SuperDork
4/29/09 2:17 p.m.
soak it in seafoam over night
D9a6M1uCBErWKsbheZscEsWq9AmI4U936ynJ6F20YnniXrROQ7pc6KTdB8ZgY2Gt
