Dusterbd13
Dusterbd13 PowerDork
10/24/16 6:00 p.m.
So, as is no suprise to anyone on this forum, my project challenge car has snowballed into the deep end.
Currently I am stripping it to a bare she'll.
Planning on seam welding the entire chassis, cleaning and painting every surface, and with the addition of Steve Stafford to the team, full cage.
We've been working at removing undercoat and seam sealer with the harbor freight oscillator tool and various scrapers. But all the stuff that seems to want to come off is off. The rest is in nooks and crannies, or hard as concrete. Hell, it may even be concrete.
We have one of the pressure washer sand blasters that Toyman used on the bus for doing all the paint and rust removal. But the rest of the seam sealer and undercoat is kicking our ass.
So, two topics:
  1. How the berkeley do we get the rest off?
  2. Full seam welding, or stitches of on/off 1 inch, and why?
chiodos
chiodos Dork
10/24/16 6:09 p.m.
Removing undercoat/seam sealer? Dry ice, most groceries will sell it
JohnRW1621
JohnRW1621 MegaDork
10/24/16 6:15 p.m.
Are the only choices warped or stupid?
Huckleberry
Huckleberry MegaDork
10/24/16 6:16 p.m.
You acid dip the whole chassis then quickly rinse and paint.
It costs about 3 challenge cars to have done but I always thought it should be doable with an acid or base spray on application one section at a time.
You would have to be nucking futz to go to those lengths to save a few ounces though.
Just take a good schit before the auto-x and you will likely be a little ahead of all that work to get the last bits out.
Dusterbd13
10/24/16 6:30 p.m.
I'm not so much doing the removal for weight as the seam welding. Can't weld undercoat. However, I also wanted it to look good.
How does the dry ice work on something like a wheelhouse or vertical surface?
Dusterbd13
10/24/16 6:31 p.m.
In reply to JohnRW1621:
Nope. Options c-z are whatever you want to call me.
ebonyandivory
ebonyandivory UltraDork
10/24/16 6:32 p.m.
Are you removing it to facilitate welding? The only thing I've read and it's been said here already is dry ice
Woody
Woody MegaDork
10/24/16 6:35 p.m.
You might want to try a pneumatic scaler for the tight spots.
mazdeuce
mazdeuce UltimaDork
10/24/16 6:39 p.m.
Once you mush it into the seams with a wire wheel it's not coming out until you weld. Then it will all come out and screw things up. Yu can use dry ice everywhere if you build a rotisserie. I can't believe you don't have the car on one yet.
Welding inch on inch off should add as much stiffness as the rest of the sheet metal can handle. Think hard about what seams need to be welded, probably not all of them. A cage that is tied in properly will add way more than seam welding.
daeman
daeman HalfDork
10/24/16 6:41 p.m.
See If you can find someone who does cryoblasting. Basically they substitute the aggregate for dry ice.
Otherwise dry ice and a needle Scaler may be more budget friendly.
NOHOME PowerDork
10/24/16 6:59 p.m.
Kill it with fire
practical demo
https://www.youtube.com/embed/NidF0yHMXt0
wheelsmithy
wheelsmithy Dork
10/24/16 7:34 p.m.
My 2 cents is one inch on, one off, if that, all done in tacks that you can hold your bare hand on before doing one next to it. Oh yeah, support the car on either its wheels, or at 4 jacking points-ask me how I know. The video NOHOME posted looks like about your best bet on digging out seam sealer. Again, ask me how I know. Good luck!
Knurled
Knurled MegaDork
10/24/16 8:17 p.m.
I keep hearing about using a liquid nitrogen "death ray" to blast that stuff off. Makes dry ice look like amateur hour.
patgizz
patgizz UltimaDork
10/24/16 8:37 p.m.
Knurled wrote: I keep hearing about using a liquid nitrogen "death ray" to blast that stuff off. Makes dry ice look like amateur hour.
That sounds like something I need
10/24/16 8:48 p.m.
Find the ounces and the pounds will come.
Stefan (Not Bruce)
Stefan (Not Bruce) MegaDork
10/24/16 8:55 p.m.
I used a propane torch and it worked just fine to remove that stuff and you don't need a rotisserie, but it will help reduce flaming hot debris falling on you.
plance1
plance1 SuperDork
10/24/16 9:54 p.m.
leave ur seams alone, they're not bothering u
Chadeux
Chadeux HalfDork
10/24/16 10:27 p.m.
Huckleberry wrote: You acid dip the whole chassis then quickly rinse and paint. It costs about 3 challenge cars to have done but I always thought it should be doable with an acid or base spray on application one section at a time.
And that's how the Spirit ended up needing a vinyl top.
Dusterbd13
10/24/16 11:39 p.m.
NOHOME wrote: Kill it with fire practical demo https://www.youtube.com/embed/NidF0yHMXt0
So, in all seriousness, why is the weed burner a bad idea?
And, best application of heat: hit and scrape while hot, or kill it with fire and come back after it cools with the oscillator?
Dusterbd13
10/25/16 7:02 a.m.
In reply to wheels777:
So how are you doing it?
John Brown
John Brown MegaDork
10/25/16 7:09 a.m.
This becomes one of those "if you have the time to do it, do it" situations.
All answers are correct. To remove seam sealer you will use heat, dry ice, scaler, wire wheel on angle grinder, scraper, blood and occasionally tears.
I'll have a beer for you tonight.
NGTD
NGTD UberDork
10/25/16 8:21 a.m.
Head on over to rallyanarchy.com and search for it. If you have thin skin, I wouldn't advise going to RA.
XhjImI7tLy8QXGmSQ8IXCCytNoF7wPYZfmanz4wf6qvdCfUXCKCrV1oCchiC7hPg
