psychic_mechanic
psychic_mechanic Dork
10/8/13 1:26 p.m.
I'm swapping turbos on an Audi S4 and when prelubing the new ones the oil is coming out of the exhaust inlet and outlet, did they forget a seal or is this normal?
turboswede
turboswede PowerDork
10/8/13 1:37 p.m.
No, that doesn't seem normal to me at all.
Swank Force One
Swank Force One MegaDork
10/8/13 1:38 p.m.
Not normal.
Check for shaft play. In and out in particular.
Cone_Junky
Cone_Junky Dork
10/8/13 1:40 p.m.
Are they actually NEW turbos? Or just swapping used ones?
Sounds like worn out bearings letting oil pass through.
psychic_mechanic
10/8/13 1:49 p.m.
New ones from an ebay parts seller, I just got off the phone with them and they want to warranty it now instead of after all the labor of putting it in. They are having me check the other one first to see if both need to be returned or just one. It's prelubed and sitting outlet side down on a blue shop towel for a bit to see if any spots appear.
Javelin
Javelin MegaDork
10/8/13 1:53 p.m.
It's definitely a bad turbo. Either they forgot something when building it, or it was a bad core. See if there's shaft movement in/out.
psychic_mechanic
10/8/13 1:57 p.m.
No in and out shaft movement
alfadriver
alfadriver PowerDork
10/8/13 2:01 p.m.
One thing to remember- if the shaft isn't spinning, the "seal" isn't working. On the exhaust side of the turbo housing, there isn't an actual oil seal, it's an oil flinger, which attempts to keep the oil out of the exhaust stream.
The other thing- turbos don't need much oil to run.
It's important that you use the proper lubrication at the right rate when doing in and out shaft movement.
Giant Purple Snorklewacker
10/8/13 2:15 p.m.
Swank Force One wrote: Check for shaft play. In and out in particular.
I find that I'm always looking for some shaft play. In and out in particular.
Sorry. Someone has to pick the low hanging fruit no matter how badly they want not to. Those are the rules.
Swank Force One
10/8/13 2:18 p.m.
In and out, out and in, round and round again.
alfadriver
10/8/13 2:18 p.m.
I find that I'm always looking for some shaft play. In and out in particular. Sorry. Someone has to pick the low hanging fruit no matter how badly they want not to. Those are the rules.
Spoolpigeon
Spoolpigeon SuperDork
10/8/13 2:23 p.m.
I seem to have excessive shaft play
Swank Force One
10/8/13 2:32 p.m.
Lies. I know you're a married man.
Spoolpigeon
10/8/13 3:27 p.m.
It's self inflicted shaft play :(
16vCorey
16vCorey PowerDork
10/8/13 3:35 p.m.
Spoolpigeon wrote: I seem to have excessive shaft play
It's not excessive until the shaft or bushings are worn to uncomfortable levels.
Curmudgeon
Curmudgeon MegaDork
10/8/13 4:03 p.m.
There's a bushing available for that.
alfadriver
10/8/13 4:06 p.m.
Or more appropriate lubrications....
codrus
codrus HalfDork
10/8/13 4:06 p.m.
When you say "prelubing", what does that entail? Are you pumping the oil in with significant pressure? Some turbos need a restrictor in the feed line or they will leak oil past the bearing seals if you run full engine oil pressure into it.
alfadriver
10/8/13 4:10 p.m.
codrus wrote: When you say "prelubing", what does that entail? Are you pumping the oil in with significant pressure? Some turbos need a restrictor in the feed line or they will leak oil past the bearing seals if you run full engine oil pressure into it.
this takes a whole different meaning based on the direction the thread took.
psychic_mechanic
10/29/13 8:52 p.m.
Just poured some in the oil feed line from a bottle and spun the shaft to move it around.
The bigger problem is now that I have installed my replacement turbos and fried up the car. I heat cycled the engine a few times to work any air bubbles out of the cooling system and let the car idle up to operating temperature. It ran great with no smoke from the exhaust even revving in the driveway, but a couple miles into my test drive I checked all my gauges again got into the throttle a bit. I was rewarded with great acceleration followed by a short screechy sound and then huge clouds of smoke from the exhaust. I'm now blowing oil out the exhaust again and I'm assuming at least one of my turbos is blown. These are stock K03 turbos on a 2001 S4, any ideas beyond chinese turbos as to what is happening? Is the oil pressure spiking way too high due to a bad regulator or something? I had just changed the oil to 0W40 Mobil 1 after the turbo swap with winter coming soon.
Junkyard_Dog
Junkyard_Dog Dork
10/29/13 8:58 p.m.
Wait, you had bad stock turbos and replaced them with stock ones?
Obviously your turbos are way too small and need to be upgraded
moparman76_69
moparman76_69 Dork
10/29/13 9:02 p.m.
Junkyard_Dog wrote: Wait, you had bad stock turbos and replaced them with stock ones? Obviously your turbos are way too small and need to be upgraded
Seems legit. I'd suggest either some Stupid Chinese Turbos, or maybe some name brand Yeah these are Chinese Too but More Expensive turbos.
codrus
codrus HalfDork
10/29/13 10:00 p.m.
psychic_mechanic wrote: These are stock K03 turbos on a 2001 S4, any ideas beyond chinese turbos as to what is happening? Is the oil pressure spiking way too high due to a bad regulator or something? I had just changed the oil to 0W40 Mobil 1 after the turbo swap with winter coming soon.
I don't know if the B5 S4 needs a restricter in the oil feed or not.
To me it sounds like you spent a bunch of time swapping out bad turbos for more bad turbos. :(
Paul_VR6
Paul_VR6 HalfDork
10/30/13 10:02 a.m.
If you are putting stock or stock frame turbos on, the stock lines are used as-is. The BW oems are often from the far east now and hold up. Might have had a knockoff of the ok offshore stuff.
mu0mthbtAXfqlEHSs5zqvHv0ic43mPMZiFna0mfezauQQQPjGDffzTAOxsG6jJ5F
