Joshua
Joshua Dork
12/9/13 1:22 p.m.
So my wife got into a fender bender this morning with her '98 Impreza Outback Sport. There is very little damage, only a broken turn signal and a cracked bumper on the drivers front. After it happened she turned off the car, checked the damage, started the car and parked it in our driveway. A few minutes later the car wouldn't start. It sounded like it was getting spark which leads me to believe it was a fuel delivery issue. About an hour later I went to try the car again and it started right up, no weird noises or anything!
Any idea what is going on? I don't want her to be stranded as it is roughly -2 degrees here today. Could this be something serious like a skipped timing chain? I read on a forum that these cars don't have inertia switch's but I found an inertia switch for the car on Rockauto so I don't know who to believe...
mndsm
mndsm UltimaDork
12/9/13 1:23 p.m.
I'd just check where the inertia switch would be. If there is one, ya know what to do. It almost sounds so me like there's something loose in the wiring.
Kenny_McCormic
Kenny_McCormic UltraDork
12/9/13 1:24 p.m.
Check that none of the fuses and relays came unseated?
Lugnut
Lugnut Dork
12/9/13 1:25 p.m.
As I understand it, there is some interia-based fuel cut-off switch in these cars. I remember when I had my WRX, I got out of the car to get propane from a gas station or something and I had my dog in the car. He was walking around in the big wagon back area, and when I got back to the car just a couple minutes later, the car wouldn't start!
I opened the hood and looked for loose wires or dynamite or something, didn't find anything. I closed the hood, got back in the car, vroom! Started right up! When I posted about it on the Impreza forum that's what they all said it was.
HappyAndy
HappyAndy SuperDork
12/9/13 2:43 p.m.
Could an important chassis ground have been disturbed in the accident? I know nothing of Subies, but if there are any grounds in the area of the impact they may need some attention.
Travis_K
Travis_K UltraDork
12/9/13 2:55 p.m.
Bad crank position sensor caused something similar on my dads 96. Is the check engine light on?
NGTD
NGTD Dork
12/9/13 3:21 p.m.
Almost all the wiring in a Subaru between the passenger compartment and the engine goes through the LF fender. A LF fender bender could have damaged that area. Main power Distribution is there too - right behind the battery.
N Sperlo
N Sperlo MegaDork
12/9/13 3:22 p.m.
Even though it sounds unlikely, I'd check the fuel reset, likely in the trunk. Weird E36 M3 happens.
Ojala
Ojala HalfDork
12/9/13 4:15 p.m.
No inertia switch. The battery is in the left front. My first guess would be the neg ground by the battery getting jostled.
fidelity101
fidelity101 Dork
12/9/13 4:47 p.m.
Stranger things have happened. In my old A4 1.8T.
The exhaust after the turbo broke, and somehow that caused the ECU to fail at the same time.
Birthdays
AecRUlFVk8R9ldrF6l39MO0mM4HyS0MUpupwNSRNClci5CDAlLyw0cdJeIuD3WJU
