Skervey
Skervey HalfDork
11/11/16 6:28 a.m.
Been thinking about this one for a while, but what does the inside of a LS1 intake look like? What makes it so good? How do the rear cylinders keep good airflow since they are so far back? Just wanted to see if anyone has a photo of one cut open or something so I can finally understand why it looks the way it does!
HappyAndy
HappyAndy PowerDork
11/11/16 6:33 a.m.
Google image search: ls1 plenum cutaway.
NOHOME PowerDork
11/11/16 6:36 a.m.
do a google image search, lots to see.
z31maniac
z31maniac MegaDork
11/11/16 8:47 a.m.
And most modern V8s have a similar intake setup.
Will
Will UltraDork
11/11/16 5:57 p.m.
Look at one of the three-piece FAST LS intakes.
novaderrik
novaderrik UltimaDork
11/12/16 8:51 p.m.
the LS1 intake was quickly rendered obsolete by the LS6 intake, which some say isn't as good as the good old cheap and readily available truck intake except for a couple of inches more hood clearance.
John Brown
John Brown MegaDork
11/13/16 5:50 a.m.
Correct, the truck intake can make more power in the real world but the passenger car is shorter.
Knurled
Knurled MegaDork
11/13/16 7:59 a.m.
Skervey wrote: Been thinking about this one for a while, but what does the inside of a LS1 intake look like? What makes it so good?
The intake ports in the heads aren't compromised to allow fitting a carburetor on top of a manifold under a low hood. They're designed for airflow, not packaging.
Manifold is secondary to that, as it also is not hamstrung by packaging issues. It's a curled over tunnel ram.
Skervey
Skervey HalfDork
11/16/16 6:40 p.m.
I know I can google but google doesn't have an option so I wanted to hear thoughts on it.
Here is some more fuel for the fire, why isn't there more options for plastic intakes for say old small block motors aka ford 302/351 or chevy 350? If aluminum intakes are way lighter then iron then why don't they have more options for plastic? We know they work, the LS1 intake works great.
$600? seems that someone could do it for less am I right? -Plastic Chevy 350 Intake-
wawazat
wawazat Reader
11/16/16 8:12 p.m.
The plastic manifolds are injection molded then assembled from multiple pieces. The molds/tools to produce each piece is very expensive when compared to die cast aluminum production "tooling". Not enough aftermarket volume to get return on investment.
cpVp4zVjkkK33mPHoVo0FC3EGKrR3CmrSfrmIcbLZZP0OCGVjEq9m3RtiGROobdo
